Results 1 to 10 of 12
October 10th, 2002 01:12 PM #1
I think I need a set fabricated for my Pajero. My rocker almost had it once. Saan kaya may makakagawa nito and for how much. I'm still studying the design and specs na kailangan. I'll probably have mine welded to the frame rails.
Heto nga pala ang sample:
October 10th, 2002 01:14 PM #2
Btw, the image came from http://www.cap510.com/ . Ganda ng TJM bumper niya (walang grille guard).
October 10th, 2002 02:44 PM #3
Yet another good offroading pic! Sir O, where do you get these?! Anyway regaring your Q... wala akong alam na gumagawa specifically for the paj (or for any other SUV for that matter) But i think you can remove the stepboards and have someone use the stepboard frame and fabricate something similar.
hope this helps
October 10th, 2002 04:57 PM #4
May requirements yung materials niyan, eh. .25" thick steel yata na tubing or pipe. Tapos yung welding specific type din (wala akong alam sa welding, sorry). Sana makahanap ako ng mura lang pero high quality. Put some Rhino Linings on the top half and I've still got a pretty decent stepboard to boot.
October 10th, 2002 05:11 PM #5
ano yung rocker panels?. yun ba yung parang tubo dun sa tabi ng pajero na pix??
para san yun?.. protection pag nagbobottom out at may nasa side na pwedeng tumama sa ilalim??...paano yun?. pag tinamaan?. eh dun sa weld point nya nde ba yun lulubog?
and what does TJM mean???
October 10th, 2002 05:15 PM #6
Yung rocker panels po ay iyong lower tone sa two-tone color ng Pajero. Yung protection po yung tubo sa ilalim ng rocker panels. Basically used for skidding over rocks and stuff kapag nauubusan ng ground clearance.
Parang pontoons siya ng bangka. May arms siya na nakaweld sa frame ng sasakyan mismo so that it can support the weight of the whole vehicle.
Very slow lang naman ang contact sa off-roading (since very slow din ang takbo ng sasakyan).
October 10th, 2002 05:26 PM #7
uhm.. if that is the lower part of the two tone.. paano mo iweweld yun sa frame eh di ba pintuan yun?....sensya na.. nangangapa pa sa terminology for offroading....
October 10th, 2002 05:29 PM #8
Rocker panels po yung gold part ng two tone.
Ang welded sa frame ay iyong rocker panel protection. Otherwise know as skis or skidbars.
October 10th, 2002 05:35 PM #9
ahh ok... hehehe. kala ko yung rocker panel mismo ang nakaweld...ehhe.thanks... uhm.. nde pa nga pala nasasagot yun TJM.. ano yun?? parang JDM? USDM?
October 10th, 2002 06:26 PM #10
ser OTEP,
ako din, pardon me for my ignorance but what does TJM, JDM and USDM means?
yo HBOY,
mas malala ang kaso ko... dehins ko din alam yung dalawa.
Sensing a hint of weakening on our 6yr old Thai Pana DIN74, went to the distributor to have it...
