Results 11 to 19 of 19
April 1st, 2003 10:29 AM #11just avoid places where there are alot of people in an enclosed space. like mall, theater, restaurant etc etc.
Better be sure than sorry.
April 1st, 2003 11:00 AM #13
Share ko lang galing sa e-mail...
For some of us who needs to travel to high risk area. This is good info
from someone. Prevention is better than cure, the best is to avoid it.
I attended a talk organised especially for our community pharmacists
tonite.
The speakers include pharmacist in PWH, QEH, KWH and a nurse specialised in the control of transmitting disease.
The talk is very informative and therefore, i want to share with u all.
SARS (Severe Acute Respiratory Syndrome) is transmitted by droplets (>5 micro) but NOT by airbourne droplets (<5 micro).
This means that it can only be transmitted if the patient coughs, speaks
outloud etc which can force the droplets out thru the mouth in 3 feet
area.
In that case, we can wear masks to protect ourselves.
So what kind of mask should we use?
Most believe that 3M N95 8210 mask is the most effective one. yep, it can
filter up to 0.3 micro particles, definitely is useful for SARS (as it is
>5 micro)but the surgical masks (green/blue in color) can also filter 5
micro particles. Therefore, it is recommended to use surgical mask which is proved to be effective and much cheaper.
Besides, there are some drawbacks in using the N95 type.
It is not recommended for those who have asthma, breathing problems and pregnant woman. As some of u who have used that before may know, the breathing resistance is very large. U may feel uncomfortable and will use yr hand to adjust it fr time to time. In this way, u will contaminate yr hand with the virus which may be present on the surface of the mask.The nurse told us this may be the reason why HO SIU WAI has contacted the disease. He wore a N95 mask when he visited 8A ward on that day, he felt very uncomfy and used his hand to touch the mask, finally he is infected.
Therefore, we should note some important points when wearing masks.
First, wash yr hands thoroughly with detergent. It's better to scratch yr
hands a little bit to wash off the virus as they can be removed by
physical friction.
Carefully identify the external and internal surface of the mask.
The colored face should be exposed. It is water-resistant, u can test it
by adding a water droplet, it won't diffuse.
Do not touch the mask after u have put it on, the exposed part may contain virus. Do not use it for a while and then take a rest by removing it and then put it on again, in other words, it can't be reused.
Use it only when necessary or with yr common sense.
e.g. It's no use to wear one at home when there're no infected or
suspected patient at home.
One important thing to note is all the masks are designed for ADULTS only. That means that even children can use it, it may not fit well. Therefore, parents should make sure their children feel comfortable in using masks. If the child find it hard to breath or feel dizzy etc, he should not use it.
The paper masks with only two layers of paper is NOT useful. It will get
dampened by droplets and can actually transmit the virus.
The nurse told us that there're only 3 diseases, Tuberculosis (TB),
Measles, Chickenpox which are tranmitted by airborne droplets (AIR). In that case, N95 should be used. 95 means 95 % filtration of air particles. The company said that they use 0.3 micro particles to test the quality of the masks. N95 standard is set by the States in 1996. For those who wear this kind of masks, they need to past very stringent tests to make sure they can fit the masks correctly. ( e.g. 25 mins breathing test)
This is something what i have learnt tonite.
It's very important information that I, as a community pharmacist, have
the responsibility to pass on to the public.
I hope that it can be helpful to u all.
April 2nd, 2003 05:21 PM #17
Ewan ko kung safe pero I'm going to the Airport and to the mall soon. :mrgreen:Ewan ko kung safe pero I'm going to the Airport and to the mall soon. :mrgreen:
April 2nd, 2003 05:45 PM #18
kakatakot naman. i will be going to shanghai on business by the end of this month eh. sana by that time wala na o minimal na lang.
April 2nd, 2003 06:01 PM #19
sabi daw sa news sa hongkong, by may mas mababawasan daw ang pagkalat nitong virus because of the weather daw.
Signature
Hmmm.... Kailangan na ng aircon service niyan innova mo. I have a blackish red innova. Bilad sa...
