Results 1 to 7 of 7
October 10th, 2003 04:24 AM #1
how would you know if offset wheels would fit into your rig? I have 33 mt's. I'm planning to get offset wheels.what are the specs?
Tsikot Member Rank 3
- Dec 2002
- 636
October 10th, 2003 07:19 AM #2Offset can differ per car model. Check your orig mags, the offset is usually stamped at the back of the rim. If you go too wide, then may place extra stress on your suspension bushings.
- 10,620
October 10th, 2003 09:09 PM #4
kimpoy, sorry! 32 pala hehe. nananaginip ata ako na naka 33 ako. hehe naka offset ba yung nauna mong mags sir kimps?
jackaroo, what other things to consider? besides stress on suspension bushings, what could be affected?
- Dec 2002
- 636
October 11th, 2003 12:17 AM #5Other things affected by too wide a rim:
Handling- adds on unsprung weight, changes orig track width
Braking- too much tire for stock brakes
Tire clearance- tire may rub against the inside fender/ suspension
- Jul 2003
- 579
October 11th, 2003 01:08 AM #6paglumiliko ka baka at full lock di na pumaok gulong mo sa fender kasi sobra palabas. wheel bearings. if you go wider make sure ung paglapad ng rim going inside and going out. kasi pag palabas yung lapad sobra stress nun sa wheel bearings, suspinson components.
October 11th, 2003 10:49 AM #7
i could avoid tire clearance problems by taking my rig higher tru suspension or body lifts. pano naman ung sinasabi ni bubbles? how to avoid it? diba merong nilalagay in between the wheels? ano yun? yun ba yung pang correct ng offset?or nalilito ako.
Traffic!
