Results 21 to 30 of 69
October 9th, 2002 05:43 PM #21
Zhero: ok noted.
sir Otep: Nothing to worry about po. I'll post pics tom sa pbase ko. I had it placed AFTER the exhaust manifold, dun sa exhaust pipe na mismo. Even if pasukan ng H20, walang problema coz exhaust gases will blow the water out. And you dont have to worry about rusting. Water pipe po ito. Water pipes dont rust. As far as i know, a lot of FXs and other diesel AUVs have this installed. Im beginning to think diesel manuf. should install this on all Brand New vehicles. It is so so effective, not to mention cheap! :D
October 10th, 2002 02:33 PM #22
Sir Otep et al:
hi! here are pics of my exhaust TUBEZ. Guaranteed 10hp increase :lol::lol::lol:
but seriously, very effective talaga in black smoke reduction.
http://www.pbase.com/mann2/tubez
- 159
October 10th, 2002 03:34 PM #23Sir Pajerokid,
Checked out your pix, nakakainspire po kayo. I'm now planning to have it done too. ;)Dati kasi puro sa mga diesel na pampasada ko nakikita yan. Meron sila nyan dahil stop n go yung driving nila and madalas sila i-test. With the mandatory testing for all, I bet marami na ring private diesel motorists na magpapakabit nyan! :mrgreen:
October 10th, 2002 03:54 PM #24
ayus ah gnun pala yun. after seeing it im planning to install one myself (este papakabit ko pala )
01 EX Ody
- 437
October 11th, 2002 11:47 AM #25Guys,
I have here the test procedure on how an emission test for diesel is supposed to be done. If you want a copy, email me privately. I will also try to upload this document for everybody to read.
Now for the rpm. The engine rpm level at which the emission test is done is dependent on 2 factors.
1. Machine factor - Some machines dictate what RPM should be reached before it takes the readings while others don't. Whether a machine dictates it or not, the user can bypass it but it would compromise the reading since some machines would not be able to detect the smoke on low RPM's thus no reading at all. Besides the probe to be inserted on your tail pipe will be the one to yield if there is a reading or none at all.
2. Human factor - If the machine dictates it, then he / she would have to follow it. But if not, any MOTOR VEHICLE EMISSION CONTROL TECHNICIAN OR MVECT should know what RPM is desired to take the readings. Or, the old style filipino mentality can come in and make your day easy or hard depends on the you know what...
Doc Diesel
October 11th, 2002 12:53 PM #26
Sirs Zhero, fierari:
I was hesistant at first to have this installed kasi nga po ang baduy at pang pasada ang dating. But ayaw mawala nung usok... even after calibration etc. So i had the nipple installed out of desperation. After my first flushing, grabe lumabas na dumi! As in meron pang solid residue which looks like very very small black particles of sand. Pero hindi pa rin na alis ang usok at high RPMs. As it turns out, blow by na pala engine ko. So after replacing the piston rings and a top overhaul, hayan, super linis na! :D
I do the flushing every 2 or 3 months.... and like i said, no side effects! di naman kinakalawang.
Tsikot Member Rank 5
- 3,144
October 12th, 2002 05:20 PM #27Latest from Manila Bulletin:
Vehicle emission test suspended
The Department of Transportation and Communications (DoTC) announced yesterday the suspension effective on Monday, October 14, of the mandatory emission compliance test of vehicles for renewal of registration in Metro Manila.
Thompson Lantion, DoTC spokesman, said that the emission compliance test initially implemented in Metro Manila last October 1 was put on hold to give vehicle owners time to fix their vehicle's engine.
Lantion said the emission compliance test will be fully reimplemented nationwide on January 2, 2003.
"The DoTC will evaluate the outcome of the initial implementation of the emission test to further improve its procedures and widen its implementation coverage to include not only Metro Manila but nationwide," Lantion said.
Lantion also said that the DoTC is conducting a dialogue with the road transport stakeholders in order to further improve the system.
"To iron out concerns in the implementation of the emission compliance tests and to further improve the system, we are having dialogue with the road transport groups," he said.
"We are also considering the effects of the recent worldwide increase of fuel prices and the coming of the holiday season. We would not want to further burden private and public vehicle owners of additional costs, which may cause public utility vehicle owners to seek an increase in fares," Lantion said.
However, Lantion said the DoTC will continue its intensified campaign against smoke-belching vehicles through roadside inspections.
- 3,144
October 14th, 2002 02:02 PM #30
ok yung tubo ah... pero parang nakakahinayang magbutas dun sa tubo.... orig MB pipes pa yun sa akin...
hmmm.. kailangan ko pang pagisipan ng maigi to...
Monk-owned R53
