Results 1 to 10 of 10
Tsikot Member Rank 3
- Dec 2002
- 636
November 29th, 2003 11:16 PM #1Question:
If the LC has a rear lock diff switch on the panel, then is it safe to assume that it can't have a limited slip diff at the same time? Is it either one in use- LSD or rear locker- but never both?
The service guys at Toyota recommend using LSD oil but don't think it has one. Does a lockable rear diff need LSD oil?
November 30th, 2003 12:53 AM #2
IMO, I don't think so. LSD contains clutch type materials that needs special oil to create friction effect. Locking diff, like in our Safaris uses ordinary gear oils.
November 30th, 2003 01:19 AM #3
usually it's either a locking diff or an open diff, but there are locking LSD units available, like the diff unit in the wrangler rubicon (locking LSDs are more common as center diffs).
November 30th, 2003 01:56 PM #5
ARB lockers are either open or locked. But the new Electrac, is Limited when unlocked and locked when on.
- Dec 2002
- 636
November 30th, 2003 07:41 PM #6Thanks guys.
Do you think using LSD gear oil would make a difference in longevity in an open or locking diff? Some say using a synthetic gear oil (like Mobilube SHC 75w90) would be better than a mineral LSD gear oil in such a case.
November 30th, 2003 11:36 PM #7
If you weighed benefits vs. cost, you're still better off using conventional gear oil + LSD additive than fully synthetic.
- Jan 1970
- 55
- Dec 2002
- 636
December 5th, 2003 07:36 PM #9Interesting read. I wonder if it's compatible with the LSD of the local trooper.
Thanks.
- 98
December 15th, 2003 08:17 PM #10
15Dec2003 (UTC -8)
Another thing to check is a factory sticker like this:
http://www.pbase.com/image/24025137
See the alpha-numeric stuff for Trans/Axle ? That means transmission is A343 (4-speed auto) while the axle is an open diff with a 3.36 ring & pinion ratio. If the axle code said "A04" or something like that, then it's got locking diffs; or if the last number was a "3", then limited slip.
The service guys at Toyota recommend using LSD oil but don't think it has one. Does a lockable rear diff need LSD oil?Last edited by Drexx; December 15th, 2003 at 08:21 PM.
10 years validity ko yehey , kaya lang sa june pa makukuha physical card :twak2: :rolleyes:
