Results 11 to 20 of 20
March 31st, 2003 08:38 PM #11
TJM ata gumagawa ng torque lockers as well as Detriot locker and other companies.
April 1st, 2003 12:45 AM #12
mahal nga e :mrgreen: di ko pa ata kaya yun.
so ngayon, concentrate na lang muna ako sa shackles and underbody protection. mas mura to e :wink:
may mga surplus bang lockers? kung meron naman for MU, dun na lang ako magagamble.
ungas,
yung rear diff lock mo ba, cable activated yun? kung air compressor din, e di hindi mo na kailangan ng compressor uli kung magdadag ka ng lockers sa harap
April 1st, 2003 09:51 AM #13
tebats,
Magnetic yata yung kay ungas.
April 1st, 2003 09:56 AM #14Originally Posted by tebats
I was assuming it was activated by an electric solenoid switch. But afrasay pointed something new to me. It has a hose running towards the engine bay. And he thought it could be also activated by air coming from the engine. I may have to check on this and gather more info.
April 1st, 2003 10:01 AM #15
Ungas,
Maari ngang air ano. Kasi yung OEM rear locker ng Pajero runs off the engine vacum so wala siyang external compressor. Pwede! hehehe.
April 1st, 2003 10:36 AM #16
Yup, di ko rin napansin yung hose papunta sa harap kasi nun, buti na lang bumili si afrasay ng Safari, may natuklasan pa akong bago, hehehe. :mrgreen:
April 1st, 2003 11:00 AM #17
its good if the safari's locker is vacuum activated, but isn't it that vacuum is pull and the compressor is push? they are totally different concepts?
i think you need air to activate the air Locker of ARB and if the safari's system is vacuum activated then it may pull air not push. i dont know just a thought.
at least if you buy the ARB set you have an onboard comressor that can inflate your tires if you air down on those trails, inflate rubber boats for your kids on the beach. and even fix a flat, put an air horn??, istall power tools. IMO lang.
- 10,620
- 10,620
Or none of the above? We've had Ferraris and Lambos burn in SLEX and NLEX in the Philippines...
Hybrids and EV
