Results 31 to 40 of 46
June 27th, 2004 08:33 AM #31
pwede kaya ironman na lang kabit ko halip na shackle? maging mas matalbog kaya?
- Jun 2004
- 476
June 27th, 2004 09:18 PM #32Originally posted by x-wind
if you are looking at changing your shocks and the main objective is to soften the ride (and your rig is leaf sprung), i would suggest go for fluid type of shocks. on my gen 1 pajero, i used rancho 9's on all fours. malambot sya.
if your adding a leaf, it'll most likely stiffen your ride a bit.
hope this helps.
June 27th, 2004 10:07 PM #33Originally posted by x-wind
eto pala yun pic
- Jun 2004
- 476
June 27th, 2004 10:35 PM #34x-wind,
so it's like rancho's "add a leaf". from what i know you will also get a lift by going for ironman's load plus. but as i said in my earlier post, it'll most likely stiffen your ride a bit.
if your objective is getting a suspension lift without the ride being more stiff, go for the longer shackles.
paj4x4
June 27th, 2004 10:56 PM #35Originally posted by paj4x4
x-wind,
paj4x4
so ibig sabihin mas magnda shackle rather than load plus.
what i want lang naman is di mababa yun likod pag loaded yun likod ko.
:offtopic:
paj4x4 san ka sa paranaque
- Jun 2004
- 476
June 27th, 2004 11:10 PM #36x-wind,
extended shackles or load plus? - this will depend on the condition of your leaf spring. since your crosswind is relatively new, i would assume that your leaf springs are still in good condition. the choice i guess is yours to make.
extended shackles will definitely lift your rear. adding a leaf (or replacing the shortest spring) will increase your rig's load capacity...you'll be able to load more stuff at the back.
by the way I'm from BF Pque. how about you?
- 10,620
June 28th, 2004 04:12 PM #38
Additional capacity load lang ang maitutulong ng load-plus, add-a-leaf conversions. Wala nga itong lifting effect. Plus magiging matagtag yan.
June 28th, 2004 10:01 PM #39Originally posted by Ungas
pag naka shackle kaya matagtag din?
paj4x4 barangay san isidro lang ako b4 lopez
June 29th, 2004 08:41 PM #40
According to afrasay, mas malambot daw ang ride ng orig length shackles.
