Results 1 to 3 of 3
- May 2015
- 7
May 18th, 2015 11:49 AM #1Hi All,
Do you have any idea on how many lift spring would a 22 ft, Isuzu BG1 Forward truck need? Mine has 7 lift springs on each side and we're thinking of putting a load of 15 tons.
thanks in advance.
May 18th, 2015 01:19 PM #2
LEAF spring.
Imho, your brakes decide what your maximum payload is, not the number of leaf springs. Kahit dagdagan mo ng leaf springs pag di kinaya ng brakes sa ibaba ng bangin ka dadamputin. Just follow the maximum payload in your manual na lang.
- Jun 2015
- 21
June 22nd, 2015 04:30 AM #3Buy a bigger truck
Adding a spring just make the life of you truck shorter
Like Yebo have said it's not just adding a spring to so you can carry more load its stopping the truck when loaded
The other way to do it is adding a pusher axle with working brakes this will also add strength to the frame
Build a trailer with working brakes (registration issue)
Buy a bigger truck
Did all kinds of work like these back in the days if I can only turn back time would have done differently
Buy a bigger truck
Buy a bigger truck
To reset MzdConnect, Press Back, Navigation, Mute simultaneously. Sent from my SM-S901E using...
2016 Mazda MX-5 Miata
