Results 21 to 30 of 37
- 3,754
February 27th, 2004 10:38 PM #21Ungas
double tire dati pero pinalitan ko na ng single tire sobra kasing liit 13" lang yata parang sa kotse lang yung naka kabit dati kaya pinalitan ko ng single tire pero mas makali.
Try ko kung mas ok yung adding blokcs nalang but I really need to increased the loading capacity..
February 27th, 2004 10:45 PM #22
Adding block will not increse its loading capacity. Ang pinaka mainam na papalitan ay buong set ng leaf springs with auxiliary sets.
Kung maliit ang gulong nyan before, maliit din ang gearings nyan. Baka durugin naman ang wheel bearings pag todo-kargado.
- 3,754
February 27th, 2004 11:12 PM #23maliit ang gulong dati pero double tire.. do you think hindi kayanin ng bearing??? di bale andyan ka naman pag nasira bearing sayo ako kuha ng advice na pang palit
Mr. President any idea how much it cost.. yung new set of leaf spring
February 27th, 2004 11:19 PM #24
We may have to check if we have that part number, bihira mabili sa amin ang wheel bearings ng dualies.
Tagal ko na hindi namimili ng truck parts, di ko na kabisado ang price range ngayon ng leaf springs. :D
Unregistered user
- Jun 2003
- 1,122
February 27th, 2004 11:30 PM #25meron po ba available locally na leaf springs ng mga toyota dyna?
perfect match po ba ito sa strada?
or any idea kung anong leaf ng ibang rigs ang mag mamatach sa leafs ng strada to give it 2 or 3 inches lift? malaki po ba magiging savings nito...compared sa bibili na lang ng arb or other after market lifter spings?
February 27th, 2004 11:59 PM #26
i pa SOA mo na lang. you wont buy pa new springs gastos mo mga 1.5k lang siguro. but if you really want to change leafs, it doesnt matter for what car as long as the length is correct, the width and the hole for the center bolt is of the same design as the strada. some centerbolt holes are not in the middle exactly so you must first have to determine it. then you will need longer u-bolts and centerbolt, spring clamps if you will just add a leaf.
Unregistered user
- Jun 2003
- 1,122
February 28th, 2004 12:09 AM #27pano naman ang spring over axel na yan...di po ba sabi ni ser otep baka sumobra taas and di na mahabol ng tbar crank
im thinking of adding a leaf tapos change shocks...
February 28th, 2004 11:27 AM #28
Invest in a good set of shackles and shocks to improve lift. SOA setups will literally give you 4-6 inch lift. While the IFS is max on 2 inch, you will have to invest a stash of cash for a down kit to be able to compensate for the rear lift.
- 10,620
February 28th, 2004 11:59 AM #29yan ang problema ko sa IFS
gagastos ka talaga,
sabagay oxymoron ang cheap hobby
- 342
February 28th, 2004 04:31 PM #30lagyan mo na alng ironman spring helper add loading capacity and lift at the same time 4000 plus lang
Monk-owned R53
