Results 11 to 20 of 37
October 24th, 2006 10:41 PM #11
Are the leaf spring pics all for 4x4's? Typically a 4x2 variant will have a spring under(unless it's a pre-runner version) and the 4x4 will have the spring over suspension(except most SUV's). Although they are both leaf spring suspension there is a still a difference in the ride. The spring under will not be as bouncy as the spring over because it does not need stiffer leafs to deal with axle wrap. Axle wrap(spring wrap) is a problem with the spring over design because of the torque generated at the axle that causes the leafs to twist into a horizontal "S" shape instead of that flattened "U" shape it is originally. If you have a spring under and convert to a spring over without using stiffer leafs you'll get axle wrap as a result.
October 24th, 2006 11:01 PM #12
sir otep, you mentioned that the safe choice for shocks would be OME over the Rancho5000. May naka comment po sakin na mas malambot nga OME but medyo too much daw because there is tendency for increased body rolling, even in braking. What do you think?
Im trying to tune my suspension for a good compromise for my Dmax.
October 25th, 2006 10:03 AM #14
- May 2006
- 913
October 25th, 2006 10:27 AM #15ah ok, thanks for the info.. do you know when they will bring the new facelifted DMax here with CRDi and VGT turbo?
October 25th, 2006 10:36 AM #16
October 25th, 2006 10:41 AM #17
Yung Nissan Frontier 4x2 ng pinsan ko, spring under pero sobrang tagtag. Yung Hilux spring-over pero hindi nalalayo sa tagtag ng Frontier.
Yung Strada spring over pero ang sarap ng ride. Yung DMax din sa spring under, ok ang ride.
So for me, kahit alin yung basic design ay pwedeng gawing matagtag or malambot depende sa tuning ng manufacturer.
October 25th, 2006 10:51 AM #18
Yup depende na nga yan sa Manufacturer. Dapat alamin nila ang sikreto ng Strada. Btw, how heavy ang load capacity nd strada? Baka naman mababa...
October 25th, 2006 10:54 AM #19
Ok, Ang tagal kung inakala na may kinalaman yong under or over sa lambot ng ride. Kung sa bagay kung tatlo lang ang dahon kahit over or under yan malamang malabot yan.
October 25th, 2006 11:25 AM #20
Strada GLS A/T's curb weight is 1860kg, Gross Weight is 2570kb. Menos mo na lang weight ng passengers. Do the math. hehehe.
just seen a 10th gen cross 200,000 miles on reddit. is this a unicorn or has the cvt been proven...
All New 2016 Civic
