Results 1 to 10 of 37
October 24th, 2006 02:01 PM #1
What are the advantages/disadvantages of having the rear leaf spring pack over vs. under the differential?
Over
Strada:
Hilux:
Under
D-Max:
October 24th, 2006 02:20 PM #2
I guess we can eliminate ride quality as one difference between the 2 set-ups. The Strada was touted as having a comfortable ride compared to all the other Japanese pick-ups in the market today, as reported by our fellow tsikoteers who testdrove it, and it has an over the diff spring set-up while the Hilux has the same over the diff set-up but has a stiff ride.
October 24th, 2006 02:45 PM #3
Ang alam ko para tumaas din ung clearance from the axle to the body. Para pwede maglagay ng bigger wheels and tires when increasing ground clearance.
[SIZE="1"]Because of the mechanical nature of suspension, all sorts of mods are available. Lifting suspension is a popular mod used to try to increase ground clearance. This is often a source of misunderstanding. A lift kit doesn't really give you more ground clearance. What it does is increase the height between the axle and the underside of the body. Whilst this does give more ground clearance for the bodywork, the lowest point on the vehicle is still the axles - or on a 4-wheel-drive, the bottom of the transfer case. For this reason, you'll often see trucks and SUVs with lift kits and larger wheels and tyres. The lift kit boosts the clearance under the bodywork whilst the larger wheels and tyres result in the axles being lifted higher off the ground. Technically of course, in a 4-wheel-drive, you don't really need a lift kit - bigger wheels and tyres would do it. BUT lift kits typically end up being required because adding on the larger wheels and tyres can often mean they will no longer fit in the wheel arches. The lift kit will help solve that problem.
Lift kits come in literally hundreds of shapes and sizes, all dependent on the final application as well as the design of the vehicle the kit is going to be used on. For street cars, typically with independent suspension, the kit will basically be longer struts, longer springs and remounted shocks. For off-roaders with beam axles and transfer cases, the suspension system is typically leaf-spring, so the kit will be a set of blocks that fit between the beam axle and the bottom of the leaf spring. Alternatively, some kits have blocks which lower the spring mounts themselves so that the spring-to-axle joint isn't changed. The image below shows an example of a typical leaf-spring beam-axle suspension system along with two examples of how it can be raised.[/SIZE]
October 24th, 2006 04:14 PM #4
Npansin ko sa pics mas madami palang dahon yong leaf spring ng DMAX compare sa strada. 7pcs yong sa Dmax, 5 lang yong sa Strada at auxiliary nalang yong isa.Walang Hanger yong Hi-LUX yong shackle nakatusok sa frame.
Kaya pala mas mababa ang Dmax kasi yon leafspring nya under difrential.
Mas ok yong strada kasi mas malambot yong set-up na leafspring nya. IMHO
October 24th, 2006 04:40 PM #5
October 24th, 2006 05:25 PM #6
it also vary on the load limit of the cargo of the vehicle... 1 ton ang sa dmax and hi lux... kaya matagtag ang ride kc matigas masyado ang leafspring niya... dont know lang the load limit cargo ng strada.... and wala naman masydo difference kung nakapatong or not yung leafspring sa diff... 1 thing for sure is tru.. ground clearance ... mataas ang ground clearance ng differential if the leafspring is underneath the diff like the dmax...
October 24th, 2006 05:30 PM #7
the very 1st dmax that was sold dito sa pinas has the 7 leafspring because it has a 1.5 ton load capacity.. which makes for a very matagtag na ride but they reduced it to 5 leafsprings like the 2004 dmax which we bought... then the newer ones was even more modified like of MEMPHIS RAINES dmax which has the flex ride suspension but still has the 1 ton capacity....
October 24th, 2006 05:55 PM #8
Spring-over-axle suspensions (the leaves are on top of the axle) is the preferred suspension set up for off-roaders because.
1. It lifts the body higher and out of harm's way
2. It makes further lifting easier (just add leaves, a lift block, or a thicker spring set).
3. It puts the leafsprings higher and out of harm's way. The diff with its rounder shape can more easily slip through terrain where the spring pack can drag. If conditions demand, the diff can also be easily armored.
As for ride quality, it doesn't really matter whether its spring over or spring under. It stil boils down to suspension tuning.
- May 2006
- 913
October 24th, 2006 10:13 PM #9i guess the first Dmax released here was CBU from thailand, thats probably why they had 7 leaf spring, because in thailand they do use the DMAx for the purpose it was designd for, which is to carry heavy loads to the market. but here it just takes family to the mall, so i guess thats why they had to reduce the leafsprings....sir otep are they bringing the 3.0 liter strada here?
October 24th, 2006 10:34 PM #10
AFAIK, the next engine after the 2.5Di-D is the 4m41 3.2Di-D also used in the Pajero.
It is still up in the air whether Mitsu will release it. Chance are they will but only after the new Ranger goes on the market.
It makes 165hp and 351Nm. The Ranger Duratorq is still king of the hill in the power race with 380Nm of torque, however.
