Results 1 to 8 of 8
July 9th, 2005 07:20 PM #1
Mga Bro,
Biglang umingay intake ko yung bang sa may air filter "TAK!!!!TAK!!!!TAK!!!!TAK!!!" ano kaya naging problema???Pero ok naman yung takbo kasi nagagamit ko pa hanggang ngayon Engine ko nga pala ISUZU 4FB1.
July 9th, 2005 08:30 PM #2
it sounds like leaking intake valves. may air filter ba sasakyan mo? if yes check if its still in one piece, if no then some thing might have gone into the intake.
July 9th, 2005 08:36 PM #3
dont use it muna..at baka kung ano pwede pumasok sa intake mo...naku delikado
July 9th, 2005 10:52 PM #4Originally Posted by ARB
Ano po ba yong leak sa intake valve???May Airfilter nman ako kaya nga lang medyo luma na nililinis ko na lang , wala kasi ako makuhanang bago replacement para sa airfilter,Marami-rami na rin akong napagtanugan na mga Auto Supply pero akoy nabigo... At tanong ko lang po di ba dapat pag-intake pahigop yung hangin???Sinubukan kong tanggalin yung air filter at hose napansin ko na pabuga po yung hangin at ingay na nang-gagaling sa intake ko.
- Jun 2005
- 17
July 10th, 2005 01:35 AM #5Tak Tak Tak ba abg sound hindi yata intake valve yan mukang nozzle tip yata problema mo try opening and closing each tip one at a time while the engine is running pagnawala dapat palitan na yung nozzle tip.
July 10th, 2005 02:10 AM #6Originally Posted by nicko
Sir Nicko,
Doon po talaga nang-gagaling yung sound sa loob ng intake hindi ko kasi maipaliwanag sa letters yung tunog pero either TAK!!!TAK!!! or PLAK!!!PLAK!!! yata yon e' , kapapalit lang po kasi ng tip nito at injection pump ay bagong overhaul
July 10th, 2005 09:11 AM #7
based on your explanation about the sound coming from the intake it seems to me that it is indeed a valve leak, meaning it does not close fully so when the fuel explodes or compressed inside the chamber its the sound you hear because the intake valve is not fully closed. there are a lot of causes its either the valves spring is cut or there iss something lodged in the valve that it cannot close fully. better take it to a mechanic and let him diagnose it.
mukhang mag top overhaul ka. better have it checked sometimes if its a sticking valve it might damage the piston when it hits it.
July 11th, 2005 01:48 PM #8Originally Posted by ARB
Na-overhaul na po ang engine ko mga a year ago , Pinatingin ko na yong engine ko sa mechanic may-leak or singaw daw yung intake ko kelangan daw pong tang-galin at i-check yung gasket kung sira,Pero kung singaw lang daw yung case nung ingay pwede daw naman pong gamitin yung ride ko yun ngalang maigay
Looks like TGPH silently edited the article and removed the entry for Velocita Motors/Ferrari.
Car Sales Data (2024)
