Results 31 to 39 of 39
May 19th, 2003 04:13 PM #31
The options previously posted were cheaper options than changing the whole leaf set. Pre-fab shackles pwedeng pasadya sa machine shop. Insist on using the tool steel para siguradong matibay. Aftermarket shackles dami ko na nakita nitong meron, some offroad magazines, and stores locally. Some are in S or Z form not the usual straight shackels.
Lifting blocks mounted inbetween the diffs and leaf springs, this option is only for leafs mounted on differentials. And may require more parts that need to be modified, ie; cross joints, transmission+propeller+differential angle. Lifting block pasadya na rin lang ito, yug iba ordinary blocks lang ang mahal.
- 10,620
May 19th, 2003 04:53 PM #32burniks
my off ride is a 99 (first gen strada)
what i did to my strada to achieve 2 inch lift is
1.change rear shackles-refabricated longer shackles dont go beyond 2 inches though. cost 640
2.torsion bar crank-can be done DIY or any talyer will do
servitek also does this, again dont go beyond 2 inches.cost 300 plus 800 alignment 1,100
el cheapo will just cost you 1,740
plus i did change my tires from 30" to 31"
and Rancho shocks for a better ride
check out BIG NASTY here: http://www.pbase.com/kimpoy316/my_ride
shackles pic included, i have them rustproofed para mas matibay
- 57
May 19th, 2003 05:13 PM #33ungas - thanks for the explanation your like a walking encyclopedia when it comes to suspension stuff :D Big help indeed
Kimpoy - Nice pick up you got there. tnx for the suggestions. let me guess harsher ride? but compensated by your ranchos of course?
ill think about it...ill go check out some more stuffs in case things doesnt work out perhaps you can show me where you had el cheapo shackles fabricated :wink:
- 10,620
May 19th, 2003 05:30 PM #34sure, the one good thing about my elcheapo suspension lift, is i can revert it back to normal in case im tired of off roading (which i dont think its gonna happen)
i still have my old shackles,
yup, torsion bar crank means harsher ride, and ride was compensated by ranchos.
but the refab longer shackles rides the same, our strada is below the axle, so they have more play, vs frontiers above the axle, less play
- 57
May 19th, 2003 08:14 PM #35Kimpoy
really? Your el cheapo shackles rides like stock?
where did you have it fabricated?
is the gen 1 stradas shackles same as the gen 2?
- 10,620
May 20th, 2003 09:00 AM #36yup rides the same!
i have it refab at my suking machine shop, just show your old shackles
its the S type
May 20th, 2003 08:03 PM #37
Nakasakay na ko sa Strada ni kimpOy. Ok ang suspension. Just don't ride in the pick up bed.
- 57
- 10,620
Suzuki JIMNY [merged threads]
