Results 1 to 3 of 3
    Jun 2005
    bakit po ganun. yung van namin hard starting. tas wen i got it to start ung idle nya 500rpm lng..sabi nung mekaniko, pump ko lng ung sa fuel filter. i did and it worked. pero lagi ganun. is there sumthing wrong sa fuel pump? dumi sa gas tank? moist? injectors? o i just need to change the filter? calibration? what should i look for? thanks po sa lahat ng mgrerep
    btw, my ride is a kia pregio.2.7 diesel.
    erik
    may be kailangan mo na palitan yung fuel filter mo ganyan din yung van namin dati hnd naman sgro kailangan pa calibrate...
    Air is probably entering your system if bleeding cures the problem.
    Check mo yung ilalim ng filter, yung lines, yung thread ng filter sa pump. Hindi ba namamawis o nagtutulo ng fuel?
    Try to do it step by step. Check mo na din air cleaner while you're there.
help po...
