Results 11 to 15 of 15
Tsikot Member Rank 4
- Oct 2004
- 2,315
September 26th, 2005 11:16 PM #11pang offroading ba yan o pang bling blings? Gawa kayo frontier club hehe sali ako. Yup stock ng pang 4x4 yun gulong ko. Rota ang gamit ng nissan.
Kung pang bling bling better upgrade your rim size and tire size as well. Kung pang offroad ok na yun 15's. try mo din ang awc na mag wheels ganda ang designs nila parang ar wheels. Para sa akin pwede na yun rota na ranger model
BANNED BANNED BANNED
- 3,790
September 27th, 2005 02:17 AM #12If you want a 1" litaw sa side, you're better off to get a rim na naka-offset palabas...ang AR na metal rims comes in different offset...personally I would want a black AR ng metal rims with the round holes around the rim na design (merun pang red ng stripe sa outer lip ng rim).
Pagpudpud ng tires ng fronty ko gagawin ko rin 235's pero wala akong budget sa AR eh...so I'll keep the stock rims. I'll also get MUD TERRAIN tires (idol ko si Ungas ganda ng gulong ng ride nya)....
September 27th, 2005 08:48 AM #13
Lemon, are you registered on Nissanbayan already? I can send you a PM of the contact info of ROTA on Nissanbayan... We encourage people who avail of discounts and services through Nissanbayan to at least be active on the board or in activities.
Beebs What makes the difference between switching the OEM 15's to aftermarket 15's is the off-set of the rims which makes the car stance much better by sticking out the tires a little more than usual (this is the case with trucks usually). On upgrading to larger rims is already a matter of taste and budget (mas mahal ang 16's and up and the stated budget of Lemon was at 23K).
- Jul 2005
- 499
September 27th, 2005 08:29 PM #14Originally Posted by vinj
Lemon, may mga wheel and tire supplier naman na nagbibigay ng terms, makakatulong yun. nanghihinayang lang ako if you'll just change wheels with the same size. go for 18" above bro!
September 28th, 2005 10:25 AM #15
IMO, it would really depend on the design of the stock wheel and of the aftermarket wheel. if the stock wheel looks good, and perhaps looks big due to the design and color, then perhaps a change to an aftermarket wheel of the same size but with a different design and color may not have the same big effect. anyhow, since you're already upgrading your wheels, do go for a bigger size para mas halata at mas sulit yung upgrade.
Depends on the level of resistance....& clout of those who'll be put to sleep?[emoji848]🤫 Sent...
[AI] Here's what they'll check during MVIS...
