Results 1 to 8 of 8
- Jun 2007
- 21
December 4th, 2007 02:50 AM #1Hello po. May problem po yung van namin Liteace (japan, 2C-T engine) sa usok nya. Malakas magusok. Pina-calibrate na nmin ganun pa rin. Tapos pag-chineck mo yung carbon sa tambutso, may kahalong langis.
Nung dinala namin sa mekaniko, nag-test drive siya tapos sabi nya may sira na raw yung turbo at poor compression (Makina?) na raw. Eto binigay nyang quotation:
LABOR:
Parts:
**Sa mga nagtataka kung bakit may kasamang shock dyan, papapalitan na rin namin kasi matigas na yung ride eh hehe**
Kung bakit kelangan din na palitan/ayusin yung Turbo: Kasi umiilaw yung warning light eh. Sabi nung mekaniko kelangan na raw ayusin/palitan.
Ang alam ko lang na mahal dyan is yung sa shock absorber mga 450 lang isa nun. Mura/Fair na rin ba yung assessment nya?
- Sep 2007
- 211
December 4th, 2007 04:10 AM #2
Tsikot Member Rank 3
- Oct 2003
- 734
December 4th, 2007 09:36 AM #3kaya sumasakit yun ulo ko sa overhaul eh....
ang haba ng listahan tapos kng malas malas ka hindi din naman yun pyesang yan yun ikakabit papalitan ng mas mura o retain nlng.
change engine ka nlng
anyway, wait mo si always_yummy dami alam yan sa model na yan
December 4th, 2007 09:58 AM #4
suggestion lang sir if you could maybe stretch your budget a bit, and if not sure on the parts availability and the work of the mekaniko, might as well buy a surplus 2C-T engine, at least mas ok un, den ung existing engine mo eh pwede mo ipagbili or pagkukuhanan ng spare parts mo .
we made a mistake with our previous hi ace, nagpa overhaul din but it did not turn out good (reason for overhauling is mausok din although may pwersa pa sya)(siguro pasaway din mekaniko)
parang mas may peace of mind kse na buo ung engine na bibilhin
sana pala bumili na lng kami ng surplus engine that time
base dyan sa listahan aabot more or less 45 thousand ung magagastos mo
December 4th, 2007 10:14 AM #5
Gumamit ng compression tester? Wet? Dry?
My suggestion is isa isa lang ang tirahin ninyo. Sa pagayos ng sasakyan kelangan sniper hindi Rambo. Do the Turbo first. Pasok siya sa mga complains mo low compression and pumping oil. Pag sira pa rin do a top overhaul then pag sira pa rin general overhaul. Just set aside the C. head and turbo kasi tapos na siya. keep it in a dry safe place cover it properly!!Concentrate on the block and components. Just a suggestion bro, Goodluck.
- Jun 2007
- 21
December 4th, 2007 11:31 AM #6Thanks po sa reply.
Gumamit po sya ng compression test (nabanggit nya yun eh) di ko lang alam kung wet or dry. Itatanong ko na lang po.
Sabihin ko yung Turbo muna ang gagawin...
Oo nga hintayin ko rin reply nya
Di rin po kasi sigurado kung maayos/gaano katagal mo magagamit yung makina eh.
- Jun 2007
- 21
December 4th, 2007 11:43 AM #7Gumamit ng compression tester? Wet? Dry?
Tumawag kami sa kanya sabi nya pareho daw una yung dry tapos wet.
Ano po ba ang pinagkaiba ng wet and dry test? Ang alam ko lang po kasing wet and dry eh market.
Bali ito na nga pala yung huling mga ginawa sa makina (About two months ago):
Pinalitan yung nozzle.
Inayos yung injection pump (calibrate ba ito?)
December 4th, 2007 02:36 PM #8
Dry is the reading of the actual compression.
When you squirt oil to c. chamber through the glow plug or spark plug and then check the compression this what they call wet. When compression increases considerable in this test your piston ring or even liner needs replacement= major overhaul. If no increase is noted valves, valve seals, valve seats, gasket or c.head ang problem or = top overhaul
