Results 31 to 40 of 53
- Jul 2003
- 579
July 20th, 2003 02:30 PM #31the thing with mine is, nung nakuha chassis nalang. so we don't really know if it began life as an suv. cuz even my injection pump is a different design from those i see here. the sound of my engine is different too. mas maingay yung local version kapag pareho walang mufflers
July 20th, 2003 03:10 PM #32
Ano ba ideal gear ratio for a Patrol na naka-35" tires?
- Jul 2003
- 579
July 20th, 2003 03:29 PM #34
Sa Pajero kasi 5.29's ang pang plus 33" tires nila. Napaisip lang ako. hehehe.
July 20th, 2003 05:40 PM #35Originally posted by OTEP
According to Motorcare in Australia, the optimal gearing for 33's is 5.21. Have not tried it since the cost of having it customized and shipped in Manila is prohibitive (about U.S.$ 1,850.00).
So, I just bought 32's BFG's for the Strada hehehe!
Buti pa Toyota (Cruisers, and Hi-lux) meron DOWNEY after market R&P's!
- Jul 2003
- 58
July 20th, 2003 11:01 PM #37
Sir woodfire,
5.29's are available upon special order from Mister Bishi of www.outdoorwire.com .Medyo mahal nga lang but it will allow you to run 33" tires with ease.
- Jul 2003
- 579
July 21st, 2003 03:10 AM #38mag regear nalang kayo ng low range. Ako palang yata ang nakapagkabit ng 38 sa gen I pajero in stock form (no regear) kaya pa nito tumakbo hanggang 70. 33's should be no problem on the street. lowrange nalang kukulangin pag off road.
July 21st, 2003 10:50 AM #39Originally posted by OTEP
Sir woodfire,
Very interesting! If this is the case and the price is reasonable, I'll sell my 32's and replace with 33's!
- 238
July 21st, 2003 04:30 PM #4033's are usually run satisfactory on stock r&p's. There is just a minute, negligible even, difference between 32 and 33 inchers.
Using a 5.29:1 r&p with your 33's will certainly boost your low end torque and acceleration. If you want your 4 by to be a monster of a climber, crawler and puller, this is the avenue you should take! HOWEVER, The downside is reduced fuel economy (very significant) and higher power band.
I'd settle for 4.88:1 OR 4.56:1 if you want to roll those 33" donuts effectively.
Or if you want good street mileage, you could just regear the transfer case to a LOWER SET. You only get it's benefits (and the warts) when you shift to low range. It's cheaper BUT there is that annoying question if it is available for your rig.
Happy trails!Last edited by Freeman; July 21st, 2003 at 04:32 PM.
Had my 2014 Altis repaired by Tireman PH in Gen. Trias, Cavite last Wednesday. Nawala na yun...
rack and pinion repair
