Results 11 to 15 of 15
July 6th, 2005 08:58 AM #11
that is why new technology leafs have graphite coating, and teflon pads in the ends to prevent squeaking.
yes rubber bushings from tires are durable, but it has its draw backs, it does not absorb impact as well as rubber ones and for 4wds it will not flex as much.
also sometimes they are made too thick that when you tighten the shackles it makes them hard to move making the ride stiffer also. go with poly bushings if you want.
- Jun 2005
- 325
July 6th, 2005 10:01 AM #12Yep, polyurethane bushings are the way to go. They are more durable than your traditional rubber bushing (kasi mas dense at masmakunat yung texture nya). Most of them come with metal inner shims. I have even seen some bushing kits also with outer metal shims. I think many 4x4 suspension tuning shops carry them as regular itmes.
July 6th, 2005 10:15 PM #13
what i do is spray WD40 sa leafsprings, pero ang nag-squeak sa revo namin minsan is yung rubber bushings between the chassis and the body nung inalog ko hehe..
July 6th, 2005 10:54 PM #14Originally Posted by Engr
i think there is a certain torque ..
for each bolts with respect to their size diameter...
Tsikot Member Rank 4
- Oct 2004
- 2,315
July 6th, 2005 11:06 PM #15try niyo pabouncin ang rides niyo normal lang yun na tumutunog. Hindi po ba masama yun tunog na yun pati na din sa metal to metal grinding sa leafs?
Latest mileage:
