Page 1 of 2 12 LastLast
Results 1 to 10 of 16
    Diesel peeps tulong naman po. Ung pick-up ko kasi (4d56) hirap na pumalo sa 100 ngayon. Pinacheck ko, di naman blowby. ano kaya ang culprit? Hindi kaya naapektuhan nung pinalift ko ng kaunti with rubber spacers? Pls advice :?:
    strainer sa i.p.
    strain sa driveshaft?
    malamang strainer sa injection pump ibig niyang sabihin marumi na, kaya starved sa fuel ang makina.
    Otomatic, Splerdu, Lui:
    Does this mean na kailangan ko na magpacalibrate? Kung kailangan na ano kaya ang price range? (sir Hanson, Doc D.?)
    What does a strain in the driveshaft mean?
    Djerms,
    Check mo muna injection pump strainer mo. May detailed instructions sa diesel maintenance thread somewhere in this forum.
    Otep,
    Ayoko muna pakialaman, siguro ipapacheck ko nalang kila hanson. If ever un ang problema, any estimates sa gastos?
    ...Otep, Nabuhay ka!! :lol:
    Hi Djerms,
    Try replacing the air filter muna...(pag di nagwork you can try to clean the strainer tulad ng sabi ng mga experts )
    I had this 100kph problem before (naovertake pa ako ng jeep bwiset :x ). Ayan I found out na my air filter is dirty, so I decided to have it replaced. After that, ayan, >100 nanaman ang lipad ko ... whooohoo!
    Quote Originally Posted by Djerms
    Djerms::: The main culprit would have to be your injection pump, 2 po ang strainers ng 4D56, although some shops opt this strainers out, you could try cleaning them first and put them back where they belong. As far as lifting is concern, di po gaanong apektado yun. :D
    ung iba po diy lang pg nglilinis ng strainer... wag k nu pa calibrate bka air filter dn... eto pa isa... ung gas tank mo palinis mo dn. ngyari sa L3 ko ayr ago ngpacalibrate ako sa teknika pro after a month prang bumagal den may ngsabi sken palinis ko dw ung tangke at ayun... blis na nman ng ambulansya ko...
difficulty at 100kph
