Results 1 to 10 of 16
November 20th, 2002 11:56 AM #1
Have you peeps experienced that knocking sound whenever you release the clutch? :?: Say hello to diff backlash! :D
Anyway, what is one supposed to do to rectify this situation, short of replacing the rear diff :?:
Both my RAV4 (SX) and Paj show symptoms of this.
As always, comments and ideas are greatly appreciated :wink:
November 20th, 2002 12:00 PM #2
Yup, nangyari na sa akin ang ganyan with my old Sentra Series 2. While driving sa expressway nag-knock then clash ang gears. Nag-leak pala tranmission oil ko at iyon kumatok transmission. Palit kami bago ng time na iyon. Check mo transmission/gear oil level mo baka mababa or you may need to change it. I hope this helps. Goodluck.
November 20th, 2002 12:35 PM #3
thanks! im thinking of changing the gear oil to 140 viscosity from 90. Ok kaya?
November 20th, 2002 11:01 PM #5
Check your crossjoints first. Your rides are relatively new. Unless you always drive like a rabbit. Keep your gear oil at 90. :mrgreen:
November 21st, 2002 12:14 PM #7
Nadinig ko sa ilan na medyo daw stiff ng kaunti ang shifting. Pero I doubt this.
November 21st, 2002 01:24 PM #8
if thats true then k siguro thicker oil for diffs which are rather worn out, dont you thnk? :D
November 22nd, 2002 12:38 AM #9
update lang:::
To my pleasant surprise, the sound i was hearing WASNT backlash! :shock::shock::shock: During my overhaul, the clutch was found missing a spring and was therefore replaced. Hayun!!! Nawala ang tunog :D:D:D
Now if only the same can be done to out RAV...... (this ones definitely backlash )
November 22nd, 2002 12:58 AM #10
Thicker oil means heavier load. Like comparing evaporated and condensed milk.:wink:
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
