Results 21 to 30 of 33
June 15th, 2007 02:21 PM #21
- Jun 2007
- 207
June 16th, 2007 01:01 AM #22ok yan mga ecu upgrade kc it not only gives u more horsepower but also fine tunes the engine,,ive used a similar ecu upgrade on my fort and ive been using it since january..ive experience fuel mileage gains..ala tlgang side effect sa mkina..also same din tyo na still searching for more power..my last power upgrade for my fort is a boost cooler which is a water methanol injection..applicable sya for all turbo charge diesel..with or without an intercooler..very safe kc may boost sensor,,manufacturer claimed of 30-90hp depending sa mixture mo ng meth,,manufactured in the usa..tpos load sensing sya with an on -off switch..tried it my fort and lakas tlga humatak..d2 p lng kmi sa davao ng ddistirbute..if enterested pm me nlng...
- Jan 2003
- 63
June 16th, 2007 08:42 AM #23That's great. Did you check whether the methanol mix corrodes the injectors? Fort is D4D is commonrail, right? I have heard some watchouts with these cooling injection systems. Did you do an ECU remap or just a piggyback chip?
I have a piggyback and my experience is great fuel economy when running e.g. highway but more guzzling when stuck in traffic.
- Mar 2007
- 39
June 16th, 2007 11:31 AM #24D-Tech Common Rail Power is a power enhancing tuning device suitable for all current models of Common Rail Diesel engines. Impressive increase in horsepower and torque. which greatly improves drive ability and in some cases even reduces fuel consumption. Horsepower gains can be as high as 20%. D-Tech works within the original Engine Management System's (ECU) mapped parameters and the maximum achievable power gains depend on the tolerance range within the OEM computer.
The fact that D-Tech works within the OEM manufacturers limits, ensures that at no point the engine is being over-stressed and this also guarantees trouble free long term use because the fuel system is still working within safe limits. The maximum fuel pressure is at no point exceeded. D-Tech comes pre-mapped for specific engine models
By using D-Tech, the fuel pressure is altered in the following way:
Idle (factory standard setting): Pressure 250 bar
Idle (D-Tech tuned): Pressure 250 bar No increase
Lower mid range (factory): Pressure 450 bar
Lower mid range (D-Tech ): Pressure 680 bar increase 230 bar
Mid range (factory): Pressure 700 bar
Mid range (D-Tech): Pressure 890 bar increase 190 bar
Top end (factory): Pressure 1180 bar
Top end (D-Tech): Pressure 1180 bar No increase
Cars that are already available for D-Tech
Toyota fortuner 2.5d4d 3.0d4d
Toyota hilux 2.5d4d 3.0d4d
Toyota innova 2.5d4d
Toyota hi-ace 2.5d4d
Mitsubishi strada 2.5di(CRDI),3.2Di(CRDI)
Isuzu Alterra 3.0 CRDI
June 16th, 2007 02:30 PM #25
- Mar 2007
- 39
June 16th, 2007 03:14 PM #26
- Mar 2007
- 39
June 16th, 2007 03:58 PM #27Our address is #6 Citiplace Bldg. J. Abad Santos St. Little Bagio San Juan M.M. Philippines its in front of Monstercars and above of Ice Monster San Juan
- Mar 2007
- 39
June 22nd, 2007 11:51 AM #28good news we dyno'd our 2.5d4d innova and it increased hp by 17% will post the dyno graph asap.
sir after installing parang mas gumaan yun kotse. 4 sale na ang D-Tech. will post po mga dealers namin.
sir our first customer was a 3.0 fortuner and the owner was so happy that after 2 days called us up again and he wants to install D-tech to his 2.5 fortuner. he was happy with the increase of power.next week yun innova niya na 2.5 naman daw lalagyan.. araw araw po siya highway kaya sobrang tuwa siya sa power ng D-TeCH
June 22nd, 2007 11:58 AM #29
Increased fuel pressure? Wouldn't this affect fuel consumption as well?
June 22nd, 2007 12:39 PM #30
meron bang long term guarantee ito? baka magkaroon ng problema in the long run?
109,606 vehicles were sold in the first quarter of 2024 | TopGear PH
Car Sales Data (2024)
