Results 11 to 20 of 20
January 4th, 2005 01:40 PM #11Originally Posted by jojo_mouth2
January 4th, 2005 08:43 PM #12
ang dmax/hilux ay mga part-time..true,walang central differential..
as i recall...
un patrol(safari series) lockable central diff nyan(may switch somewhere in the dash.)for offroad use
ung sa 2nd gen++ pajero may central diff(3rd gen may VCU) yan(4H) lockable din(4HLc),kaya pwede dinang pajero as full-time 4wd.
January 4th, 2005 10:18 PM #13Originally Posted by alwayz_yummy
GQ or Y60 Patrol Safari series never had center diff lock. Maybe you were pertaining to differential locks alone. Which locks the rear axles left and right to keep the engine power equal to both tires of the vehicle.
Center diff lock per se, is located inside the transfer case which locks transfer of power to front and rear propeller shafts. Which can also be compared with part time 4WD which is always locked when engaged in 4WD mode, high or low gear.
- 10,620
January 5th, 2005 09:25 AM #154HLc
4 High Locked Center )differential
guys driving on a 4H in a part time 4WD vehicle is NOT SAFE, so wag ninyo nang isipin ang wear and tear drivetrain.
imagine paliko ka from a busy highway then suddenly nagka binding effect at may mabilis na car sa other side... kaboom!!! now would you worry about drivetrain???
January 5th, 2005 06:27 PM #16Originally Posted by Ungas
January 5th, 2005 06:30 PM #17
ask ko lang din....diba ok mag-"4H" ang partime-4wd when in gravel/unpaved roads?been doing it going to palayan city...sa shortcut para iwas sa bayan ng cabanatuan...
January 6th, 2005 09:49 AM #18
it is ok to use 4h on gravel and unpaved roads. kung di pwede dun then there is no use for our off road capabilities. i think what kimpoy meant was using 4h on paved and normal roads.
January 6th, 2005 09:58 AM #19
just wanna clear myself din,e....unpaved gravel stretch kasi ung road(along with dump trucks)kasi on 2H mode there lots of swaying especially * 60kph++..mahirap kasing mapasunod sa dumptruck,walang makita because of dust..kaya obligadong bumilis..
January 7th, 2005 02:00 PM #20
The system in the Pajero is a true full time system with an 'off' switch (2H) in case you do not want 4WD. In 4H (unlocked C/D), the Pajero is operating in the same manner as a RAV4's 4WD is. Constant power to all wheels but at a variable ratio between front and rear axle (to eliminate binding).
The DMAX and Hi-Lux do not have such capabilities.
Btw, I'm back to 2H for the meantime. Kapag inclement weather or off-roading ko na lang ginagamit ang 4x4. Though I try to use it at least a few days in a month.
Latest mileage:
