Results 11 to 20 of 36
December 18th, 2002 03:22 PM #11
Yun sa Gen 1 paje same ang front and rear crossjoint. Armand, mga P400 nga siya. So P800 all in all.
Otomatic:::yun pinatubo pixs pina scan ko pero di pa tapos ata. try mo alisin yon propeller then rev mo engine. pagnawala yon kalansin (yes kahit nakahinto madidinig mo yon) sa crossjoint na. LSD ba yan? check the gear oil level.
December 18th, 2002 05:22 PM #12
yung rear ko lang kumakalog ser Alf, yun lang siguro papalitan ko :D I cant wait to change it para wala nang prob :D
December 18th, 2002 05:34 PM #13Originally Posted by pajerokid
otomatic: Sir, pa check mo din yung diff. mo. Minsan kasi pag malaki na yung gap in between gears ng diff., pinagmumulan din ng "clunking" sound. Ang alam ko may adjustment yun as per my mechanic. Pero kung hindi naman luma yung ride mo "which I'm sure is not ", malamang sa x-joint lang yun. ;)
Try to check the center bearing if there's any.
December 18th, 2002 07:27 PM #14
kupaloids::: madali lang sana magpalit ng univeral joint, kaya lang, mahirap tanggalin yung circlip (locking clip) :D Youre correct po. pag hindi natanggal yung sound after palit ng x-joint, differential backlash na yan kailangan ng diff overhaul, i-aadjust yung mga gears sa loob ng bungo :D
- 267
December 18th, 2002 09:49 PM #15Originally Posted by afrasay
ill try your advise. sana x-joints lang nga.
yung transmission ba pinanggagalingan din ng clunking?
LSD ba yung pag inikot mo gulong(both are raised) pareho sila ng direction?
- 267
December 18th, 2002 10:08 PM #16Originally Posted by kupaloids
pag hindi po nakapasa yung ride ko sa test na advise ni afrasay, eh malamang na mabuksan ang diff. ko.
wala po siyang center bearing kaya alin sa tatlo(x-joints, diff., transmission) ang culprit.
- 267
December 18th, 2002 10:26 PM #17Originally Posted by Ungas
i-try ko din itong idea mo, baka nga me pag-asa pang di ma opera diff. ko
- 267
December 18th, 2002 10:27 PM #18Originally Posted by Ungas
December 19th, 2002 08:57 AM #19Originally Posted by otomatic
December 19th, 2002 12:52 PM #20
Kapag inangat mo ang parehong gulong ng LSD at pinihit mo ang isa, dapat same direction din ang ikot nung nasa kabilang side. Open diff yung baligtad ang ikot ng kabila. Hope that clears things up.
What vehicle and what's your budget?
