Results 21 to 26 of 26
November 25th, 2003 08:39 AM #21
badsekktor,
Si KCboy ata ang nakita mo.Hehehehe. Blue ang sa akin, eh. Si KCboy naka-triwave na tire guard sa likod.
November 25th, 2003 08:54 AM #22
pissword::: Pwedeng i-repair ang alloys. KAso di ko alam yung direct shop. Nakita ko lang sila kumukuha ng mga aayusing mags sa 2nd hand tire dealer. Nasa 2-3k ang isang mags kasama na paint and buff dun.
badsekktor::: Don't forget that an inch changed in your overall tire diameter will change your speedometer's acuracy. An inch wider than your stock mags will definitely boost some ego but more on the safe-non-expensive adjustments.
Yung Pajero ni KCboy may clone that's almost exact duplicate as his ride. Same color, same tire rack, roof rails and lights. The only thing that differentiates the two are the legal plates and the bumper mounted foggies. :D
November 25th, 2003 10:54 AM #23
sir ungas salamat.... ang mahal pala parepair ng mags kahit stock lang
August 23rd, 2006 05:11 PM #24
sabi nila ang alloy lalo na pag ndi makapal madaling masira ang suspension ng tsikot, kaya madami gumagamit ng steel.,
August 23rd, 2006 05:23 PM #25
Just to set the record straight....
alloy = combination of a metal plus some other element/s
steel = is an alloy of iron and carbon, etc
mags = short for magnesium alloy
so "steel mags" is an oxymoron
"alloy wheels" could also refer to steel wheels since steel is an alloy
and most "mags" are actually aluminum alloys...
yeah I know I'm OCLast edited by Psylocke; August 23rd, 2006 at 05:25 PM.
- Feb 2011
- 2
February 5th, 2011 07:57 PM #26i have a question mga bos..mron ako gen 1 strada with 15inch rims stock ata ng gen 2 strada..gusto ko ksi palitan ng AR mags 15inch din pero mas wider ng konti dun sa stock rims ko ngyon..pero gulong ko is 235/75 sya if mgpalit ako AR rims mgfifit kya yung gulong ko sa much wider na AR rims? khit di ako mgpalit ksi mkapal pa gulong hlos 80% pa.
salamat
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
