Results 11 to 17 of 17
August 24th, 2006 03:55 PM #11
Kung nawawala, mukhang vacuum problem iyan. May araw na may sufficient vacuum, may araw na kulang.
Ganun kasi sakin. I drive it one week in 4H and it can build sufficient vacuum. Pwede ko gamiting ng 2H the next week. Pero natatalo talaga yung vacuum kaya mag-blink ulit and I have to shift to 4H. In my rig, may konting leak ako sa clutch master and yun ang suspected na cause ng vacuum leak.
Maganda nga ipa-check mo na. Pero in the meantime mag-4H ka muna para hindi pwersado ang system. Yun kasi ang default setting niya. It only 'forces' itself into 2WD by using vacuum.
Btw, ganun siya so in case the system fails off-road, you will not lose 4WD capability.
August 24th, 2006 08:09 PM #12
- Nov 2004
- 115
March 25th, 2007 01:35 AM #13up ko lang itong thread na ito..
similar problem kasi sa pajero ko..
dati ung 4WD indicator, blink ng blink.. ngayon totally wala na! i checked the fuse busted sya.. when i replaced the fuse, it got busted after few days.. san kaya ang problem nito?
ung solenoid na nabanggit dito.. ano ba itchura nun?? i want to go under and find the thing.. saan ba sya located madalas?
March 25th, 2007 05:17 PM #14
The 'solenoids' (at least that's what they call it most of the time) is on the passenger side fender. Para siyang may rubber knob na bilog.
March 25th, 2007 05:27 PM #15
yan ata yun vacuum switch na mayrun din sa patrol safari. eto naman yun nag control ng rear differential lock nito.
March 25th, 2007 05:32 PM #16
Yep. Magkamukha sila ng Patrol.
- Nov 2004
- 115
March 25th, 2007 11:43 PM #17ay teka! yan ba ung nasa engine bay na may hose?
or under chassis ito?
Traffic!
