Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 47
    Originally posted by Sheep
    d pa naman ganun kaingay pero nadidinig ko na parang iba na ang tunog compared before.
    and pag kaka start ko pa lang di na pareho dati na pino kaagad may nararamdaman na akong nginig (parang sinisinok) after 2-5mins nawawala na what seems to be thr prob?
    With regards to your first querry, iba na talaga ang tunog ng makina after running 5K from its brand new state. Fitted na lahat ng internal moving parts. Ika nga break-in period is over. :D
    On your second state, pag bagong andar ang makina lalo na after having it rested for a couple of hours. Bumababa na lahat ng langis sa oil pan. It is natural for your engine to sound like there is metal to metal contact, infact that is what's happening inside. It takes about 10-20 seconds before the oil gets pumped internally, ofcourse it all depends on how big the engine and its oil pump is. Kaya masama yung pagkakaandar pa lang ng makina then sabay ng mataas na rpm agad, let it idle and oil circulate first before putting more strain on your engine.
    regular naman ang change oil ko every 5000 sabay palit ng oil filter i always use orig mitsu parts ang hindi ko pa lang napapalitan ay ang fuel filter na nabasa ko sa manual due 20,000 km ito kaya ang cause ng pag sinok? sorry sir medyo ot pero ask ko na rin
    Di ko sinusunod pag dating sa mga filters ang manuals. 20K kms. kung nasa ibang bansa ka at siguradong malinis ang fuel na papasok sa makina. I change my fuel filters every 10K kms. Minsan nagkakatubig sa loob kaya nahihirapan ang fuel system, or pwede rin naman itaktak kung tubig lang ang laman. Kung dirt and grime naman, mas makakabuti pang palitan na it will just choke your fuel system.
  2. FrankDrebin Guest
    Nakikipost lang po.
    So, 14 yung clearance gap para sa mga 96 model na 4d56?
    Originally posted by FrankDrebin
    Nakikipost lang po.
    Nope, it is on 16 clearance gap.
    Jan 1970
    pardon me for my ignorance.. ano histura ng valve clearance.. he.heh.e..
    Frank, Ungas :: Ano yung 16 na clearance na sinasabi nyo? YUng gap? Gap for 4d56 is straight 25 - warm. intake and exhaust.
    But then again baka pang TDIC versions lang to. baka iba sa N/A
    Thanks for all the replies.
    Jun 2003
    thank you you rin sa paliwanag sir ungas
    12 ang gap ko sa 4d56 as adjusted by ferdie.
    Mar 2003
    Sir Alfred,
    Sa manual, 10 supposed to be ang gap ng 4d56. Anong advantage ng mas malaki ang gap?
    Hmmm.... parang mahirap explain kung ano itsura nun ah... well it is simply the gap between valve and adjust screw or in some other engines valve rod and adjust screw.
    Yung binabanggit ng clearance na 10, 12, 14, 16, 18... 25 eto yung feeler gauge measured in millimeters ie; 0.10mm, 0.12mm, 0.14mm so on and so forth.
    A mechanic told me once that it is better to adjust it when the engine is cold. May metal expansion daw pag warm ang engine and adjusting it would get different results.
4D56 Valve Clearance Adjustment
