Results 1 to 10 of 20
- Oct 2007
- 7
October 5th, 2007 10:20 PM #1[SIZE=4]Hello Fellows,
Ask lang po ako some advice, Is it true na mas maganda raw ilagay yung 100% tubig keysa 50/50 coolant& water mixture sa radiator for a 14-yr old 4D56 N/A engine, sabi kasi nila pagluma na raw radiator mo marami ng scales inside at tinatanggal ng coolant causing restrictions on the system.
thank you & more power!!!
[/SIZE]
October 6th, 2007 01:26 PM #2
hmm.. sa pagkakaalam ko po, isa sa mga properties ng coolant ay anti-scaling, so pine prevent nya nga ang formation nun especially kung hard water ang nagagamit mo.
kung worried ka na yung existing dumi ay kumalat at magcirculate sa cooling system mo, siguro maganda kung pa flush mo or overhaul yung radiator bago ka mag lagay ng fresh coolant/water mix.
- Apr 2007
- 11
October 6th, 2007 08:28 PM #3hello everyone! ask lang po ako, pwede bang lagyan inter cooler turbo or turbo charger ang 4D56 engine ng L200 mits. model 1995? balak ko palagyan ng inter cooler or turbo charger ito L200 pero hindi ko alam kung anu disadvantage niya
- Sep 2006
- 1,335
October 6th, 2007 10:58 PM #4Of course, pwede lagyan ng turbo & intercooler and L200 mo.
Pero mas mabuti kung hindi mo na ito baguhin for the following reasons:
- Hindi mo kailangan and extra power ng turbo/intercooler sa L200 kasi magaang lang ang pick-up na yan.
- Malaki ang aabutin sa gastos ng conversion.
- Luma na ang ride mo kaya wag mo na masyado gastosan.
- Baka lalo ka pa magkaproblema kung hindi magaling and pag-convert.
Dieseldude
- Sep 2006
- 1,335
October 6th, 2007 11:13 PM #5Ok ang 50/50 coolant solution over plain tap water dahil:
- coolant solution prevents boiling pag mainit ang coolant. Mauubusan tayo ng tubig pag nag-boil kasi magiging steam ito. Water boils at 100 Deg C or 212Deg F at sea level.
- Nilulubricate din ng coolant solution ang water pump and coolant passages ng makina.
Bye,
Dieseldude
- Apr 2007
- 11
October 7th, 2007 06:27 AM #6
- Apr 2007
- 11
October 7th, 2007 06:47 AM #7sir gud am again, may binili kasi akong elephant foot sabi ng mits. tech pwede ilagay sa L200 ko pero nun pinalagay ko na hndi naman pwede, may remedyo pa ba yun sir o papalitan ko din ba ng cam shocks, sayang kasi yung 8pcs. na elephant foot na binili ko. baka sir meron kang masasabi
thnx
- Sep 2006
- 1,335
October 8th, 2007 12:44 PM #8
- Sep 2006
- 1,335
October 8th, 2007 12:59 PM #9Sorry, we don't do engine modifications. We only do repairs and turbo installations on stock engines.
We do not encourage modifications as this will be prone to a lot of possible problems. If you decide to proceed with your plans, you will also have to spend additionally for calibrating and modifying your existing injection pump to one with a boost compensator. Calibrating your injection pump for turbo application will increase power, but will result in black smoke. The boost compensator will control your black exhaust problem.
Note: Your stock engine may not be able to handle the additional power it will generate.
Be careful,
Dieseldude
October 9th, 2007 11:32 AM #10
I hear a surplus pajero 4d56 turbo costs 16k. then probably you will need a 4d56 turbo injection pump for the boost compensator. maybe 5k? intercooler costs 2k.
I suggest change engine nalang para sigurado walang problema for 30k.
