Results 11 to 13 of 13
December 5th, 2003 09:56 AM #11Originally posted by roydok
I was quoted 2k for our Tamaraw. Tanong ko lang po pwede din po ba ang 3M undercoat to rustproof the insides of the doorpanels, hood and fenders?
Originally posted by xox
wats undercoating?
December 5th, 2003 11:28 AM #12[i]
Name applys to itself. Basically it is a chemical made of same quality or better than paints. Applied to the under parts of the vehicle that will need rust protection. Metal parts will not easily form rust if painted or coated with something to protect it. [/B]
for clarification lang naman pre :D
the chemical used for undercoats is different from the material use for making your car paint. If you'll read the label on 3M's undercoating, it's made of a rubberized material. Such rubbery material, is not used as a resin for making car paints. and also, rubber is not better per se compared to the chemical used for making car paint. Minsan pa nga, may halong asphaltic material ang mga undercoats, hence the black color.
for undercoating kasi, the main purpose is to form a barrier against water and stones that hit the underside of your car - stones causes scratches under your car and those scratches are sometimes deep enough to break through the anti-corrosion coatings on the car metal,e.g., kung na dip coat or na-galvanize man yung metal na ginamit sa car body mo, pag nagasgas yon, exposed na yung bare metal. Once that happens, water, which carries oxygen, gets to the scratch, and starts the corrosion process - in layman's term kalawang. Corrosion is not brought about by water, it's the oxygen that's in the water.
Now why rubber or asphalt as undercoat material? rubber obviously is flexible, so good protection against stones, di sya madaling masira, tatalbog lang yung bato. plus, it hates water, di tumatagos ang tubig sa goma or sa asphalt. kaya yun those 2 factors combined make for a good and cheap undercoating material. added side effect pa nito, rubber deadens vibrations, -- di sya nagtatransmit ng sound kaya meron din syang noise insulation effect.
ang precaustion ko lang sa mga magpapa-undercoat. bantayan nyo maigi yung pag linis ng ilalim nyo. patanggal nyo lahat ng dumi at kalawang na makita. Useless kasi kung hindi. once na magkabreach yung undercoat nyo, the undercoat can also trap the water inside/between the metal and the coating. mas matagal exposure sa tubig, mas malala kalawang.
yun lang po.
bow
Daming issue ng SU7:grin:
Xiaomi E-Car
