Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
    Mga peeps, pwede bang i-lift ang 2WD? Gusto ko kse i-lift ng kaunti yung revo para mag kasya kahit mga 27" tires. Gusto ko lang kaunting lift sa harap lang, sa likod no problems kse leaf spring. Sa harap kse torsion bars. Meron ba kayong alam na shop na gumagawa nito? Thnaks!
    revo168,
    Torsion bars are very easy to lift. You just have to adjust the bolts at the back end of the torsion bars (halos katabi na ng transmission). Tighten to lift, loosen to lower. Just don't forget to get your wheels and headlamps realigned afterwards.
    Heto po ang link on how to do it. Mitsubishi ang ginamit pero the principle is exactly the same:
    http://www.4x4wire.com/mitsubishi/tech/minutemods/torsion_bar/
    ganun lang?? gano kalaki yung pwedeng mai-lift by adjusting the bolt?
    Sa Pajero sagad na ang two inches. Ganun din on most pick-up trucks.
    revo168::: i recommend goodyear servitek! after your torsion crank, pa steering alignment ka coz gagalaw ang settings mo. :D
    aba galing niyan a... may downsides ba yung bolt-turning na yan?
    ever thought about putting a 2" body lift instead?
    for me mas ok ang suspension lift, kasi anytime madaling ibalik sa stock ( i was told by sir freeman)
    mbt::: the only disadvantage is that you have to spend a thousand bucks to realign the steering :D And i think limited lang yung height increase dun sa allowed ng bar crank (correct me if im wrong guys) :mrgreen:
    Medyo sagad na yung torsion bars ng revo ko, eh! ano pa ba ang pwede para mai-lift yung harap? magkano ang body lift? saang shop gumugawa nito? Thanks again.
2WD Lift?!?
