Results 11 to 19 of 19
February 13th, 2006 04:05 PM #11
Depends on the car naman. Mine takes 15w40 (gasoline)... others take 10w or 5w.
Toyota is my choice
- Aug 2005
- 2,063
- Nov 2005
- 8
February 17th, 2006 10:49 AM #13In hot climates like the Philippines, 15w-50 or 15w-40 are the recommended mineral based engine oil but if you can get a hold of a 20w-40 it is much better because it has a narrower spread between the numbers, meaning less use of polymer which
is the substance that breaks down. Consumers Report tested the filtermag and they reported it works.
http://www.filtermag.com/?app=Automo...&makes=MERCURY
- Nov 2005
- 8
February 17th, 2006 10:50 AM #14In hot climates like the Philippines, 15w-50 or 15w-40 are the recommended mineral based engine oil but if you can get a hold of a 20w-40 it is much better because it has a narrower spread between the numbers, meaning less use of polymer which
February 17th, 2006 01:54 PM #15Originally Posted by islandermike
February 17th, 2006 11:33 PM #16Originally Posted by islandermike
bro, ok lang ba after drain yun oil tank lagyan mo ng sae 40 and run engine for 10-15 mins. and drain again then refil with 15w-40. ok kaya to sae 40 panglinis lang sa loob.
- Nov 2005
- 8
February 19th, 2006 07:10 AM #17Originally Posted by x-wind
SM Current For all automotive engines presently in use. Introduced in the API service symbol in November 2004
CH-4 Current Introduced in 1998 for high-speed four-stroke engines. CH-4 oils are specifically designed for use with diesel fuels ranging in sulphur content up to 0.5% weight. Can be used in place of CD, CE, CF-4 and CG-4.
SL Current For all automotive engines presently in use. Introduced in the API service symbol in 1998
CG-4 Current Introduced in 1995 for high-speed four-stroke engines. CG-4 oils are specifically designed for use with diesel fuels ranging in sulphur content less than 0.5% weight. CG-4 oil needs to be used for engines meeting 1994 emission standards.
SA, SB, SC, SJ, SE, SH ARE ALL OBSOLETE
February 20th, 2006 02:52 PM #18Originally Posted by islandermike
- Nov 2005
- 8
Traffic!
