Results 11 to 15 of 15
September 11th, 2007 11:09 AM #11
I remember this CDI about 20 yrs. ago! hehehe
I assembled one for my old Ford cortina and what do you know? It worked! You should buy the old Electronics Enthusiast magazine with the article about it when you buy the kit. I don't know if the article is included in the kit so you should make sure. The wiring to your engine electricals is simple enough. The problem is if you have the skills in assembling/soldering the electronic components on the circuit board.
Also make sure that the case will be waterproof and place it on the engine compartment where water will not reach it. (Rain or floodwater!) Good luck!
- Dec 2006
- 273
September 14th, 2007 01:36 AM #12Nakagawa na ako nun..actually, nilagyan ko pa nga ng switch, from electronic ignition to conventional ignition (para in-case na magka-trouble sa electronics, you'll still be rolling kasi naka-conventional ka), and also, nilagyan ko din ng staller (means that, mag-crank lang sya, walang kuryente sa ignition system). nakapag-kabit na ako sa mga corolla at lancer box type, ganun din sa mga owner type jeeps, at yung mini austin...basta lahat ng makina na gumagamit pa ng contact point.
BANNED BANNED BANNED
- 3,790
September 14th, 2007 04:23 AM #13ipost mo naman complete details nyan dual ignition (electronic - conventional)... baka merun ka ring pictures to follow.
- Dec 2006
- 273
September 14th, 2007 07:24 AM #14wildthing,
sori, wala akong mapo-provide na pictures. alam mo ba yung kit na galing alexan (nai-post ni kinyo)? minodify ko lang yung circuits nya. dun sa diagram kit, walang switch para sa conventional, electronic at staller. Yung conventional pala means you gonna still use the contact point, as in yung original ignition system ng kotse, yung electronic ay yung electronic device, at yung staller naman ay naka "neutral"..walang kuryente. ginamitan ko ng 3-way toggle switch.
September 14th, 2007 08:57 AM #15
How can you say the your contact point "won't last long?".... If it's non- functional (as in it won't last long),- then you can't start your engine as it channels the spark to your spark plugs at the precise moment of the engine cycle....You can also adjust this by revolving your distributor. However, I suggest that you use a timing light to check or validate.
Normally, you just clean it(contact point) by running a fine sandpaper in between the contacts. And then, wiping it clean by cloth.
Are you using the right value for your condenser?
Is the resistor still in series with your coil? Or, was it bypassed?
3808:fish:
Denali Lights, Dial Dim, & Soundbomb Review—Is It Worth The Premium? | Behind A Desk MotoDeal
Auxiliary Driving|Fog Lamps
