I just replaced the piston rings and valve seals because smoke was coming out but still there is white/blue smoke! when i had the semi overhaul they also checked the turbo manifold for signs of an oil leak in case the turbo was damaged but there were no traces of oil and turbo is not noisy in anyway..the mechanic said he wanted to cut the pipe of my muffler because it seems like there is an obstruction because smoke comes out of the air filter if revved..but not sure if this could be causing the smoke..i have a toyota starlet gt turbo 1995 ep82![]()
