Results 1 to 3 of 3
- Jul 2005
- 122
September 30th, 2009 11:17 PM #1Hi, here's the situation... binaha sasakyan ko but it caused me just a little damage. nabasa lang carpet. My question. Is it ok to just dry the carpet? Actually, di nako nagpa-detailing at ako na mismo naglinis ng carpet while intact with the floor(di ko inalis). Its dry now and the odor slowly faded away bec I sprayed lysol disinfectant.
Ang concern ko lang yung nabasa na metal floor beneath the carpet. di ba mag-corrode yun kasi talagang di ko na inalis ang carpet e. Thanks in advance.
September 30th, 2009 11:55 PM #2
Sadly there is no shortcut here. If the carpet gets wet (like in the floods) or submerged in flood water, you are obligated to remove it asap. Clean the carpet w/ deteregent, rinse and air dry thoroughly before reinstalling it. Do the same for every nook and cranny on the metal floor of the "bare" car.
October 1st, 2009 11:48 PM #3
kahit carpet lang nabasa you need to have it removed and cleaned. Some carpets have a rubber sheet liner below and this traps water. To be sure have it removed, washed and dried.
Suzuki JIMNY [merged threads]
