A lot of coolants already have built-in ultraviolet dye.
You just need an ultraviolet lamp.
*batang_raon... any updates?
It happens on the Outlander, too (the late fan)? Might just be precautionary programming in the ECU, then, unrelated to the problem.
red food coloring will do the trick... mura pa.
have you checked you radiator cap? just happened to my hiace, 3/4 ang temp. tapos mga isang tabo ang nadagdag na tubig every morning... changed the rad cap.... back to normal na
Have taken into consideration your inputs sirs, thanks. I failed to bring the car to the casa dahil color coding pero I took some observations right after arriving home.
Turned the engine on and just rode the car around the village to warm it up. After mga 5 mins. siguro ung temp.gauge nag-3/4 na naman. So balik agad ng bahay. THEN, ung pagpatay ng makina tapos aabot pa ng mga 10 secs. bago mamatay ung fan? Lumala ngaun... kasi nung naobserve ko ung delay sa shutoff ng fan, pagkalagay ng susi sa ON ng ignition uli, di naman umaandar. Ngayon di pa umaandar ung makina, nasa ON lang ung susi, pero umiikot na agad!
Ung power window naman na naindicate, normal ba un or hindi? Kasi saken ganun din.
Isa pa, pano ba tignan via UV lamp? Inilawan ko kasi kanina, pagkailaw... ano ba dapat makikita? Ung nakita ko kasi may pagkaneon ung kulay, then may isang part na pure black lang talaga ung kulay niya (kumbaga sa kaha ng sasakyan, ung buo kulay neon sabay ung hood kulay black). Ano po kaya ibig sabihin nun?
Guys, sorry for the delayed update.
Sent the car to the casa since Tuesday pa (day after coding), and kahapon lang narelease ung findings ng casa (kesyo raw maraming tinanggal et al) so kahapon lang din ako nanotify regarding the situation.
Most of your guesses were right, UNFORTUNATELY. Why? Eto report saken:
1x replace thermostat
1x replace fuel gasket
1x refill all oil levels (perhaps dahil 40t PMS 'to)
1x replace radiator (di ko narinig mabuti) fan
check ECU programming
check tubings
at marami pang iba... total na singil saken 43K!!! Upon asking kung ba't kelangan palitan ung thermostat (dahil nga masyado pang maaga), sabi kesyo raw aftermarket nakalagay (hello?! Sa kanila ko lang dinadala ang sasakyan ko!), ung fan nung tinanong ko kung baka naman nakarekta, sagot saken di raw nila alam... tsk. Sabi ko ung necessary lang muna sa PMS ang gawin. Pagkapullout ko ng unit sa Tuesday baka patignan ko sa ibang shop for 2nd opinion. Hay...
come to think of it, ako nagrequest na icheck ung mga parts na un... perhaps sinasamantala dahil tingin nila eh kutob ko un ung may mga tama? Wag naman sana...
Shucks, warranty issue sana yung thermostat... wanna try another casa?
*niky
Sir un nga eh. I was expecting na they would tell me na papalitan naman dahil under warranty pero the reply I got was kesyo raw "aftermarket" nakalagay... Really weird how that happened. Di naman ako naglalagay ng aftermarket parts sa engine parts ng sasakyan. Mula nung binili 'to sobrang dami ng inconsistencies ng parts niya everytime na dinadala sa casa. Ung trunk motor na nagpapagana ng button sa keyless entry para di na gamitin ung susi "nawala" (ngaun sinisingil pa ko for parts ng mechanism nun kesyo hindi pa raw talaga kasama un sa stock, hello gumagana noon pagkagaling lang po sa inyo tumigil sa paggana), ung headunit ko di na gumana ung changer right-after nung ipa-PMS ko one time (ito buti pinalitan),ung spare tire ko na bagong-bago ung gulong napalitan rin ng pudpod. I dunno, ung mga SA dun oks naman, problem nga lang ata eh di nila minomonitor ung mga gumagawa mismo ng mga sasakyan.![]()
Syet talaga! Aling casa yun?!? You should report it to the management!
I know Mitsu is suffering, but they really can't afford to put up with people like that!
I already did several times sir. As in SEVERAL times. I even posted my concern once here in the forums at nagbigay pa nga saken ng info si sir happy_gilmore kung sino dapat kausapin, after nun nanahimik ung anomalies sa mga pagkawala sa parts. Then after 2 PMS may nawala na naman, un mababaw lang dahil pampalit lang ng spare tires, madaling palitan, pero etong ngaun eh kakaiba talaga. From price to parts grabe.... sigh
It's simple, really. The warranty will be honored by any dealership. If you are quite dissatisfied with their service, tell them you are a member of a Mitsubishi car club (not far from the truth...), tell them you are fed up completely with the service, and that you are taking your business and your friends' businesses to another dealership, and that you'll tell everyone you know to stay away from that dealership.
It may or may not work, but at least you'll get it off your chest... and whatever other dealership you go to after that will probably be miles better.![]()
