Results 71 to 80 of 90
- Mar 2021
- 636
September 8th, 2021 01:15 PM #71
September 8th, 2021 01:25 PM #72
Context and application is everything.
WD40 has grown to include countless other products. But in our case, I believe the thread was about the original "WD40 - Multi-Use Product".
WD40 is a lubricant... but only under specific use cases. Would you use gear oil in an engine? Gear oil is a lubricant. Engines need lubricant. Again, context and application.
At most, WD40 Multi-Use is a short-term lubricant, which is perfect for loosening up crusty hinges, tools, and such. Would you use motor oil to dislodge a stuck lug nut?
In electric fan application, WD40 can help loosen up the sleeve bearings if it's really dried up and stuck. This can prevent scouring the brass sleeves when disassembling the rotor. But it needs a more permanent lubrication designed for the particular interface during assembly.
I think it's unfair to vilify WD40 if you have misconceptions about its usage.
September 8th, 2021 01:35 PM #73
- Nov 2009
- 3,273
September 8th, 2021 02:56 PM #74Its a penetrant. If you use penetrant, don't forget to replenish the lost lubricant.
- Jan 2008
- 4,397
September 9th, 2021 10:30 AM #75
- Jul 2013
- 2,443
September 9th, 2021 10:48 AM #76
- 46,336
September 9th, 2021 11:16 AM #77surfing old posts, i saw this.
then it came to me,
in the olden days, we would use kerosene (gaas!) to de-grease and clean bicycle chains and other automotive parts.
when we were kids, dad would teach us to degrease and clean our bicycle chains, using kerosene and paintbrush.
this activity actually prepared us for the more-daunting acts of degreasing and cleaning our cars' parts later on in life.
September 9th, 2021 12:05 PM #78
- 46,336
September 9th, 2021 12:11 PM #79
- Jun 2011
- 726
September 11th, 2021 09:02 PM #80Sa stockyard ng casa, iyong mga rims/mags may plastic na film/"cling-wrap" para hindi talsikan ng ulan at kalawangin ang disc brakes.
Puwede kaya spray ng WD40 sa disc brake para same effect? Or may mas okay na spray para dito?
Sasakyan namin naka open parking. Ngayong tag-ulan puro talsik at makapal na ang kalawang sa disc brakes. Bihira din gamitin, kaya hindi na "sand-off" ang kalawang.
Bakit kailangan mag log in sa LTMS portal, wala namang option dun for vehicle registration?
LTO car registration and late registration fees
