Results 1 to 20 of 20
    Nov 2007
    Hi there auto gurus.
    Just want to know what could be the possible problem/s that causes this jerking RPM problem and causes the (almost) shutdown of engine after hi rev either on highways or even at a standstill??
    car details:
    '97 Nissan Sentra SS
    approx 140K mileage
    Had a pms at speedyfix wherein i had a change oil, sparkplugs and cleaning of the MAF (?). Changed the simota ail filter recently.
    The car engine doesn't sound normal when this problem occurs. Any ideas sirs/madams??
    Anyone checked the intake and intake manifold for leaks, cracks, holes, etc?
    Nov 2007
    sir when i brought it to speedy almost 2 months ago, the mechanic told me that it was caused mainly by the worn out spark plugs and possibly by unclean MAF (dont know what this is??)
    the RPM was at 1.4k and could not be lowered daw because the engine would eventually choke and shut off. i think it cost me more in terms of fuel consumption but it did save me from having the same problem again.
    after almost 2 mos of use the RPM was normal at 1k but i noticed that after hi revs (above 3K) from say travel at C5 or edsa, the engine demonstrate said unusual noise and the jerking of the rpm when i slowed down.
    as for checking of any leaks, the mechanic at speedy didnt mention anything about leaks but rather concluded that the trouble was caused by the sparkplugs and the maf.
    Nov 2007
    the chances of this problem usually goes on a ratio of 2 out of 5.
    3 out of 5, it goes well nman as normal.
    meaning it doesnt occur everytime but when it does i am really bothered that this might cause accident for me or for other motorists near my ride at the time.
    Nov 2007
    mga sirs/madams, sinumpong nnman yung jerking rpm na sakit ng ride ko kanina lang.
    while having a high speed and hi rev along C5, after slowing down the rpm needle gauge went berserk again. then when i checked after i parked, we noticed that the unusual sound came from the engine or somewhere inside it. parang tunog diesel engine cya.
    mukhang malayo po cya sa air intake or sa simota filter nya although i would be bringing this car to casa para ma assess cya ng husto.
    any more input on what are the possible problems??
    free po ba ang magpa check assess sa mga casa?
    If I may make a suggestion...put back the original air filter assembly. I have an acquaintance who drove a stock car (forgot the model, sorry). While the car exhibited no abnormal behavior, this acquaintance of mine decided to install a Simota air filter kit.
    After installation, the car's behavior changed. Sometimes the rpm would rise for no reason, and then dip drastically. This was immediately after the Simota change.
    After a few weeks of this, he decided to go back to the stock setup. He removed the Simota, reinstalled the factory air filter housing...and presto!
    The car's behavior went back to normal. No more erratic rpm changes.
    Nov 2007
    thanks for the input sir civicvti.
    but this problem wasn't present when i bought the car as 2nd hand, taking into consideration that the air filter was already changed to simota kit. i only noticed this problem almost a year after. the car was running perfectly smooth before.
    as assessed by the mechanic, he said that the worn out sparkplugs and the dirty maf was the cause of said abnormal behavior (jerking of the rpm).
    Quote Originally Posted by Excalibur View Post
    Bakit hindi mo muna palitan ang sparkplug at palinis ang MAF sensor maari ring dahilan ng problema ng makina mo.
    Aug 2006
    if problem still exist after replacing spark plug ang cleaning MAF, try to reset ECU and perform idle learn...
    first start engine and wait to reach operating temp...
    then turn off the engine and pop up the hood to locate fuse box and remove ECU fuse for about 10 secs.
    after that replace the fuse and close box. start the engine and let idle for 10mins with closed hood and no electronics accessories are on.
    after 10 mins. turn of the car, idle speed are not reset.
    Start the car and go drive like you normally would so the PCM can relearn the fuel maps.
    obd2 na ba yung car, me capability ba na ma scan ito? mas maganda siguro ma read ang mga sensors para malaman ang most probable cause ng problem. remember may mga malfunctions na hindi basta mag flag ng trouble codes and check engine. i suspect a bad maf or air leak after the maf sensor and or iac issues.
    yung jerking , technically called misfire yun . most likely cause nya spark related, you probably need an auto technician not a mechanic to properly handle this trouble.
    Nov 2007
    Quote Originally Posted by speed unlimited View Post
    sir napa linis na po when i had my pms sa speedy. replaced all the spark plugs and the mechanic cleaned the maf. ok nman cya for a while but after almost 2 mos. present nnman yung problem.
    tinaasan yung idling (naging 1.4K) para daw wag mamatayan ng makina, a little high but like i posted earlier it was just for a while. took some extra mileage from my regular fc but the problem was solved. after quite some time nag normalize na yung rpm (1K) but the problem cropped up again.
    Nov 2007
    Quote Originally Posted by arieslhon View Post
    Ok sir, I'll try this one.
    hope i can locate the ECU fuse.
    Nov 2007
    Quote Originally Posted by t2erns View Post
    sir ano po yung "obd2"??
    saan po pwde magpa read ng mga sensors?
    Im at maybunga, pasig right now at ang pinaka malapit po dito na shop ay rapide.
    although madami negative feedback nga lang sa rapide but i tried having a radiator flush service from them, mukhang ok nman sila at very accommodating. about 2 weeks pa lang ata silang bukas.
    Tol ,sakit na talaga ng Nissan na makina ang Erratic idling. Marami pinanggagalingan Dirty IACV , Throttle body iyong sa akin sinubukan kong mag lagay ng grounding kit nag stable idle niya at maganda performace at lighting niya steady kahit bukas lahat accessory problema kasi iyong lumang stock na grounding kit iyong pinakakapitan naguumido rin iyan at kalawang . Suggestion lang.
    *Excalibur
    You might want to have your ignition coil checked. It can also result in erratic idling when it isn't in good shape.
    Nov 2007
    Quote Originally Posted by CivicVTi View Post
    *Excalibur
    ok sir. I'll have it checked by a nissan casa and get a price quotation from them.
    hopefully it would not be that pricey. sa casa kasi it seems that they are bound to see more than what is needed to be repaired thereby incurring sky rocket costs.
    Nov 2007
    ok nman cya sir wag lang susumpungin.
    i noticed nga pala one time sinumpong then namatay makina, after i started it (nsa intersection nka stop yung light) after i switched the engine on biglang naging ok nnman yung andar (pati tunog) nya. may multo????! hahahha :beam:
    Sep 2010
    Got the same problem although only occurs when the airconditioning system is on. After revving up, bigla ako mamamatayan minsan sa kalsada, which is very dangerous dahil tumitigas ung break pedal kapag nakapatay makina ko. Btw my car is diff though, it's a civic esi. Idle ko tuloy naka set sa 1.2k kasi pag naka on ac, it would drop 200-400 units, other than that, after revving, bagsak another 200 or 300 or so tapos balik dun sa menos ng 200-400. It's pissing me off, di namin madetect ung problema.
    Jun 2010
    Quote Originally Posted by opay21 View Post
    faulty servo/IACV symptoms.
Jerking RPM after hi rev
