Boss try mo magpa-SIMUL! Yan ang suggestion sa akin ng friend ko if you want a little more kick with your 2E! BTW, ito yung explanation ng simul by "legobrainboy" of grupotoyota:
anu po un simul?
modifying the throttle linkage so that the opening of the secondary chamber's butterfly is dictated by how far you push the gas pedal and not via vacuum.
kasi in stock form, ang carb natin vacuum activated yung secondary chamber. so the carb will feed more gas and air into the engine only when it wants to and medyo may delay pa ito. kapag naka-simul, basta pigain mo yung throttle, bubukas yung secondary chamber therefore giving your right foot direct control over the the carb's behavior.
If you want more infos, read this thread:
http://www.grupotoyota.com.ph/board/...er=asc&start=0
