Results 21 to 30 of 35
March 30th, 2004 02:18 AM #21
whaaa... a/t ba yan REVO mo? The more na dapat hindi mag tope yan. The auto tranny should take care of the shifting for you. Kahit nga papunta sa Baguio kahit naka Drive kaya pa rin.
- Nov 2002
- 117
March 30th, 2004 09:57 AM #22Hmmm, bakit kaya may-tope pa din? I observe ko pa siguro kung mag-i-improve pa or magiging worse pa.
March 30th, 2004 11:38 AM #23
try nyo Petron Blaze (RON96). Nawala ung tope ng sasakyan ko... yung nga lang medyo mahal. Pero basta happy ka naman, di bale na ung added cost...
- Mar 2004
- 89
March 31st, 2004 10:27 AM #24Tope..... I have a 7k na revo, what I did to remove detonation was:
1. Use NGK plugs....bpr5ey-11 or any NGK basta "5" yung heat range.... (ayaw ko nang denso na stock... it breaks down 3k pa lang takbo ko from installation )..... if you have time, experiment, kaya lang magastos sa plugs.....iba-iba kasi response from diff plugs.... I 've used the bosch platinum.... ok naman...
2. GAp it well... pang sinabing 1.1mm do it at 1.1mm
3. Use BLAZE! (nde ako taga pertron.. pero it has the highest octane rating!......which means lesser chance of detonation)
4. Timing..... ang recommended ay 5 degrees BTDC (ingat kayo... may mga taong nagpapangap na marunong mag adjust nang timing nang 7k na EFI.... kasi set mo muna dapat yung ECU for initial timing.... (may lalagyan ka nang jumper wire).... mag rereset yung ECU tpos pag na set mo na yung 5degrees, aalisin mo yung jumper..... mag cocompute na nang timing map yung ECU )
5. check your air filter baka barado.... pati yung MAF baka madumi...
just my 1 cent....
- Nov 2002
- 117
March 31st, 2004 04:03 PM #25Zdre, thanks for the input.
So far pareho tayo ng kapalaran pala. Pareho din tayo ng method of resolution. I'll try Blaze sometime, kapag naka-tiyempo ng magandang Petron station. So far, OKs naman unit ko sa Velocity.
Yung bang REVO mo eh totally nawala ang tope? Or meron pa din ba paminsan-minsan? Lalu na pag uphill at naaalangan ang gearing?
March 31st, 2004 04:28 PM #26Originally posted by stroker_200
...Ang daming puwedeng pag-gamitan....pang-palengke, pang-grocery, pang-hakot (buhangin, lupa, halaman, bagahe, lipat-bahay, etc. etc), pang-kasal, pang-opisina, pang-harabas, pang-picnic (maski sa loob puwede) at kung anu-ano pa na hindi ka mag-aalangan (compared sa kotse at sa mamahaling SUV). Matibay pa!
Are you insinuating car/sedan/SUV and AUV bashing by your post? I don't seem to get your point and deem inapopriate for this forum.
- Nov 2002
- 117
March 31st, 2004 06:05 PM #27My apologies Mr. Moderator. I didn't realize na OT yung comment ko, at maaaring ma-mis-interpret pa.
Thanks for pointing this out....will be more careful next time.
March 31st, 2004 06:41 PM #28
OT:
No harm done, just be careful posting next time. We don't want our fellow members over reacting to some topics which I know meant no harm. :D
- Jul 2003
- 15
April 2nd, 2004 11:56 PM #29Hi, Im an owner of a Revo SR manual transmission.
Acc. to the Revo manual, the gasoline octane rating must be 95 octane or higher.
Right now, im alternating my gas between XCS Plus (95) and Blaze (96+), ok naman ang hatak....
- Nov 2002
- 117
April 6th, 2004 09:11 AM #30Nabasa ko din yung manual, specifically the section that says to use RON 95 or higher. What surprised me is the recommendation of 2 casas (Toyota North and Marikina) to use Super Unleaded instead. I did try, out of curiosity. Pero ganun pa din, tumotope.
Right now, I'm using Velocity from Ivanson's gas station (the one in White Plains and in front of Honda Libis). So far so good. I did try the one in the Fort, pero tumotope unit ko dun.
