Question lang po mga sir,
My ride po is civic 2000 a/t....meron po kasing tsk tsk tsk sound, pina check ko po sa mechanic sabi po distributor bearing and need nya buksan.... I'd like to ask po muna an opinion before ko pabuksan.
Thanks po.
Thanks po.
baka tunog ng slipping belt? check your belts ..tighten kung pwede tighten.. or palitan. kung bearings... usually parang metal whistling or grinding sound yun.
maybe it's your tapet clearance... adjust lang ng clearance ng rocker arms... kung mas bumibilis magtsktsktsk pag tumatas ang rpm un yon... pwede din belts... fan belt, aircon belt, powersteering belt... un lang pwede mgtsktsktsk dyan...
hard to tell where the sound is comming from without seeing the car. have a 2nd opinion done siguro.
kung cgurado kana doon sa sinabi ng mechanic at narinig mo thats the right time na sure ka na yun talaga ang tumonog.. kng ako yun hinahanap ko talaga..![]()
