Results 1 to 10 of 20
December 13th, 2006 12:07 AM #1
help naman. may toktok na sound sa ilalim ng altis ko. nung umpisa, medyo mahina pa. pero after a week, naging malakas at madalas na yung tunog. napacheck ko sa cruven, mukhang d nla mahanap ang problema. kasi pinapalitan nila yung bushing ko. nung una wala na yung sound, pero bumalik ulit. tapos sabi nila baka shocks na daw yun. e sa unang check nila sa shocks ko, ok naman daw. anu kaya pwde maging problem? d kaya sa velocity? pero kahit hindi ako lumiliko, tumutunog pa rin. any ideas kung anu pwde maging sanhi nung tunog?
December 13th, 2006 05:12 AM #2
kapag dumadaan ka lang ba sa lubak tumutunog??? could be one of TOO many things... Personally I would jack the car up and check every little details underneath... Check mo rin ilalim ng trunk mo baka mamaya may naiwan ka lang na tool...
December 13th, 2006 06:44 AM #3
hindi po, kahit walang lubak or hump yung daan, tumutunog pa rin sya. mas madalas lumabas pag nagbrabraking ako.
December 13th, 2006 07:13 AM #4
Nangyari din sa akin yan. It all started when I had my CV joints replaced sa Servitek. Evident lang sya pag nagbe-brake. Actually, until now andun pa rin yung toktoktok sound (mahina lang). At first it was irritating, but I've since learned to live with it. Braking power did not diminish, so pinabayaan ko lang. Its been over 2 years, ok pa naman ride ko
December 13th, 2006 07:27 AM #5
sa akin kasi malakas, nakakairita yung tunog. pinacheck ko naman yung cv joint ko, sabi nila ok naman daw. umiingay lang daw yung pag lumiliko. so possible na sa cv yung problema?
December 13th, 2006 09:16 AM #6
most probably the bushings. kung ok pa yan, baka kailangan lang ng lubrication.
December 13th, 2006 09:33 AM #7
baka stabilizer link. ako ganyan din eh. kahit hindi lubak. yun pala stab link lang.
then check mo rin yung spring kung sumasayad sa ibang part.
December 13th, 2006 10:04 AM #8
December 13th, 2006 10:17 AM #9
Ako may toktok din sa Altis ko pero pag lumulubak lang. Yung tunog parang samay gulong...papacheck ko plng sa 5000km ko.
December 13th, 2006 12:09 PM #10
On the 95 Corollas swaybar bushing/link sa rear wheels yung problema. Toyota is known for using the same setup on future models, have a look see at this part.
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
