Results 31 to 37 of 37
Tsikot Member Rank 5
- Nov 2003
- 3,849
March 10th, 2006 01:53 AM #31you only replace the other drive belts kung may bungi or tama na. no need if they are in good condition.
- Feb 2006
- 28
March 10th, 2006 03:54 PM #32How much are the following quality parts for Honda civic 94 hatchback 1.1L engine
1. Timing belt
2. tension bearing
3.oils seals
4. valve cover gasket
5. distributor O-ring
6. water pump
Is it recommended to replace the other belts aside from the timing belt as part of the 80Tkm maintenance?
- Oct 2005
- 29
March 10th, 2006 06:37 PM #33sir speedyfix, pwede po ba mag-quote ng labor and materials cost for timing belt/tensioner (orig and replacement part) para sa 96 civic vti? maraming salamat...
- Nov 2003
- 3,849
- Feb 2006
- 28
March 12th, 2006 09:18 AM #35does changing timing belt needs the engine to be out of the engine bay of the car?
- Nov 2003
- 3,849
- May 2005
- 208
May 13th, 2006 02:57 AM #37naka bili ako timing belt sa casa. tataka ako chinese yung sulat. yung do not bend sa plastic. parang nilagyan lang yata ng code ng honda. made in japan yung sticker. yung timing belt china?
Production of the next gen Kicks confirmed .......
2025 Nissan Kicks
