Results 51 to 57 of 57
June 14th, 2007 04:32 PM #51
Thank You sir DJ,
Celect, DDEC, PEEC concentration ko po.
Question 1) In trucks, what is a Jacobs brake system and how is different from the regular brakes?
- Oct 2004
- 278
June 14th, 2007 08:52 PM #52*4JGtootsie
On the thermostat assembly I've posted, there's only one thermostat valve... Once the valve is fully open (to let water from 3 flowing), the 1 is blocked by the valve...
Thermostat closed:
Thermostat partially open: the smaller valve on the bottom blocks the 1 passage...
Same principle as the two-thermostat valve assembly you have posted, but eto isa lang...
June 14th, 2007 09:53 PM #53
Thank You sir EssB for the clarification.
If you didn't take it out from the housing medyo hindi ko maiintindihan.
Bale po the smaller valve will never close full either partial or fully open. That is why there is no bypass line.
And the bigger valve will only open when coolant inside the engine needs cooler water from the radiator.
Tama po ba?Last edited by 4JGtootsie; June 14th, 2007 at 10:06 PM.
- Oct 2004
- 278
June 14th, 2007 10:19 PM #54*4JGtootsie: The smaller valve will block the 1 when the main the thermostat valve is fully open. Thus, water from radiator going to the suction line of water pump will flow freely.
...pero syempre, lalamig na naman sya pagdaan ng water from radiator, thus, the thermostat valve open or close... probably just on partially open often times.
June 14th, 2007 10:56 PM #55
er, nobody is bashing, were just discussing. i only answered d_j's post because it was partly wrong. di ba sabi ko he is correct up to a point. and in fact in his later post i agree with him, an engine without thermostats driven at low loads (answering the thread starter's question if he can drive it around with no adverse effects, at low loads that is) can and may be driven as if the thermostats were there. but i will agree with it only if that condition is maintained, otherwise i would not. sorry guys but if it seemed i was bashing, i was not. it comes with the trade kasi, in my job we either do it right or we do not do it at all. when i overhaul an engine i want it to be able to give 100% power when needed, not 1 percent less. and there are times when we even run engines at 110% for a few hours! an engine without thermostats can not do that, and that is why i did not agree with d_j.
another reason why i answered as i did was that i did not want people reading this thread will come to believe that it's ok to remove the thermostat. i prefer to give tsikot people the whole picture rather than something that is "pwede na". better decisions are made if the information is more complete, agree? i can only do that if i point out d_j's post, nothing remotely personal meant there.
hey d_j, hope i did not ruffle your feathers. sometimes i can be very undiplomatic hehehe!
June 15th, 2007 07:25 AM #56
my bro and I always disagrees on this. he belives in removing, while I believe thermostat should remain.
for diplomatic reason...
I told him that I will drill two 3mm holes in the thermostat. and he agrees... I found this idea in a number of articles in the web.
June 15th, 2007 11:35 AM #57
..seems like this has already been answered, I'll check back regularly on your nwe thread and see what I can do to help out. The method that worked best for me was to read books and then I would consult more experienced techs/engineers on things that I don't quite get/understand.
yebo, I can totally see where you're coming from, I would explain things again but I believe that my other post clarified that already ...no worries
