Originally Posted by
wiper
your temperature gauge will remain constant when it reaches the normal temperature. If it rises when in highway like nlex, something might be wrong with your clutch fan that is the silicone oil is not enought or dried out. What you need to do is filled your clutch fan with one or two tubes of silicone oil. You can check ur clutch fan by rotating it if it offer some resistance or rotating freely. If it rotates freely that means you lack silicone oil.
especially when traveling in highway when the clutch fan lack silicone oil it will just rotate because of the strong wind and not functioning as it used to be to blow the cool air into radiator fins.
