Results 21 to 26 of 26
December 17th, 2007 03:26 PM #21
I think walang masamang mangyayari. Ive done that on numerous customer cars and theres no adverse effect whatsover.
well, of course may cooling system ang lahat ng kotse para ma prevent ang over heating, assuming nag ooperate ng mabuti ang cooling system.
I meant of "extreme heat" when idling (plus add up the hot outside temperatue) kasi ang makina, mas maiinit ang temp pag hindi umaandar. pero hindi naman sa mainit to the point na mag o-over heat, pero mainit to the point na nasa boiling temp. din ang oil (specially pag Mineral Oil). so mas maganda pa din na laging nasa constant operating speed ang makina, nasa moderate RPM's.. hindi naman yung tipong nasa Redline palagi, kasi like what you said, nag gegenerate ng "extreme heat" ang makina pag nasa higher RPM's (mostly near & obove Redline) which is definitely true.
but if the engine is running at load (again at moderate RPM's.. hindi lang naka Idle), obviously nag si-circulate ang Oil pressure/flow inside the engine. which lubricates (and also cools.. believe it or not) the internal engine parts at the right oil pressure and temperature. when the engine/vehicle is running, obviously na nahahanginan ang makina (not only by the fans.. but by outside air as well) so bumababa ang underhood temps, reducing engine heat.
kaya on some engines, there are Oil Coolers. its like a small "radiator" but for engine oil, I have that on our Racecar and on my personal cars. which really helps reduce Oil temperature, specially when the car is at higher speeds, at higher RPM's.
keeping your engines Oil temperature low (below boiling point) is really important. its the same as keeping your engines Cooling system temp. low. which in both cases reduce engine wear and failure.
aite, peace.
December 17th, 2007 03:49 PM #22
synthetic all the way......if the professional racers are using it and can protect their precious and expensive engines then the more that it can also do that to my puny stock engine....
I think almost pareho lang ang gastos eh, like before when I was still using mineral oil, meron ako pina pachange oil na P1k lang for the labor,filter and 4 lites of valvoline oils....so kung every 5k kms ang change oil ko is 2k din ang cost, while meron naman si speedyfix na promo P2.1k for everything but at least 8k to at most 10k kms ka mag change oil so pareho lang ang gastos....
the advantage is you have the added protection of the synth oil, on your engine....
December 17th, 2007 05:47 PM #23
Had my PMS today. Switched from synth to mineral. There was no significant change in performance. Try ko ihataw mamya para malaman ko kung meron talaga difference .
OT: My SA told me that there was a fuel "additive" (forgot the term) for the engine to cleanse the nozzles (Is there such a thing? Nagoyo yata ako nung anaknangtipaklong na yun!:outcold . But I hope it will help in addressing the "tope" problem.
Tsikot Member Rank 5
- Nov 2003
- 3,849
December 20th, 2007 11:18 PM #24the most impt thing is to really know what viscosity to put sa engine. if you use synthetic pero put the wrong one then this is even worse than using mineral na tama...
December 21st, 2007 12:39 AM #25
sir.. sa alam ko po..
may commision kasi.. pag synthetic oil
pag may flushing
pag may engine wash
pag may oil additive
pag may fuel additive
pag change color ang car
pag ikaw ang nag refer sakanya sa accesories
pag detailing
pag may maganda ang feekback sakanya ng.. customers.. sa.. followup reports
:D
- Nov 2003
- 3,849
December 26th, 2007 09:19 AM #26actually, the SA's get commissions no matter what oil you use in casa. whether it's mineral or synthetic.
basically it still boils down to what is better for the engine...
considering a Ferrari has an average price range of 20-25M. multiply that with 666 units sold then...
Car Sales Data (2024)
