Results 21 to 29 of 29
Tsikot Member Rank 4
- Jan 2003
- 2,979
November 10th, 2006 11:14 AM #21im not sure pero before pa kumalat yan spoilers saka skirts na yan eh napanood ko sa tv, something like a documentary about trucks na bumibyahe sa europe. since cross-country ang byahe nila eh ok daw na lagyan ng spoilers saka skirts yun truck para medyo bumilis yun takbo saka bumaba yun fuel consumption... im not sure though kung significant yun effect
November 10th, 2006 11:32 AM #22
You want a "rear-wing", I think this is the most common term if the wing is placed on top of the trunk lid (not hood as you described ).
On most of our rides it is purely aesthetic lang, to give character to the car. This is a great add-on only if done properly meaning it should not be ridiculously shaped or oversized na parang sampayan na.
As a heads up, the rear wing is used in race cars to push the car downward so that it won't skid off the corners when it turns at high speeds. Same principle sa wings of a plane only in reverse lang; a plane's wings generate "lift" when propelled at high speed. On a car the wings angle is reversed to create that push down effect.
There are a number of these available, the more popular ones is the R-Type and S-Type.
- Nov 2006
- 72
November 10th, 2006 11:43 AM #23
November 10th, 2006 06:23 PM #24
try to contact "corics" of grupo toyota.
http://www.grupotoyota.com.ph/board/...3bfa931eaf971d
November 10th, 2006 06:46 PM #25
Actually, since most spoilers are kind of useless anyway, I'll take the ducktail over the wing, as it doesn't block your view out the back.
November 10th, 2006 07:09 PM #27
November 11th, 2006 03:40 AM #28
if your car is FWD, a spoiler has no performance benefits.
it's really to help RWDs and AWDs keep the back wheels in contact with the ground.
November 11th, 2006 09:56 AM #29
10 years validity ko yehey , kaya lang sa june pa makukuha physical card :twak2: :rolleyes:
