Results 1 to 10 of 17
July 5th, 2004 08:39 PM #1
Bakit mag iiba ang reading ng speedometer pag lumaki or lumiit yung gulon? Curios lang po.
- Jul 2003
- 49
July 5th, 2004 08:57 PM #2You know, the odometer sensor is connected at the transmssion after the gears. It is designed to count the rotations of the shaft which drives the wheel and translates to the distance traveled. The reading takes into account the original size of the wheel (circumference). So, if you put a smaller wheel, the odometer indicates more than you really traveled (But you increased the torque at the wheels). Conversely, a bigger wheel results to under-registration.
July 5th, 2004 08:57 PM #3
larger tires means more distance traveled at the same rotation of the shafts/axles, vise versa for smaller tires/wheels.
sandali, ang tanong mo is bakit nagiiba ang reading ng speedometer? pano mo nalaman na nagiba nga?
hindi sya nagiiba, nagiging inaccurate lang. if you have large tire diameter than your stock tires, yung 100kph reading sa speedometer mo might translate into 105kph in actual speed.Signature
July 5th, 2004 09:00 PM #5
ito po ay dahilan sa kapag ang isang gulong kapag lumaki, mas matagal o babagal complete ng isang revolution or ikot, gawa nang ang radius nito ay mas malaki. ganun din po kapag lumiit ang gulong. mas maliit ang radius kaya mas madali siyan maka-ikot, therefore, bibilis sya.
July 5th, 2004 09:15 PM #6
Thanks sa info. Nalinawan na ako. May nakita akong site may Tire Size Calculator check this out baka makatulong.
http://www.miata.net/garage/tirecalc.html
July 5th, 2004 09:36 PM #9Originally posted by pepengtom
ngek, alam mo naman pala eSignature
July 5th, 2004 09:50 PM #10Originally posted by boybi
sinusubukan lang nya siguro tayong mga tsikot peeps kung alam ba natin yan
Monk-owned R53
