Results 21 to 30 of 36
March 2nd, 2005 05:59 PM #21
im using denso iridiums for 7000kms already. just had it cleaned last week, and ok pa rin up to now.
March 2nd, 2005 06:26 PM #23Originally Posted by ssaloon
March 3rd, 2005 02:55 AM #24
Meron na ba naka-try ng SplitFire... Ito gamit ko ngayon and okay naman. Never been cleaned since kinabit 10,000 kms ago and still going strong. got it for 1,400/set..
quote from the manufacturer:
Q: Why should I pay more for SplitFire Spark Plugs?
A: The key reasons: SplitFire patented split 'V' ground electrode helps deliver more complete combustion. Result: Maximum percentage of fuel is converted to combustion energy not partially burned exhaust, for performance only SplitFire can deliver.
Q: Will SplitFire Spark Plugs work with a "high performance" ignition system?
A: Yes. SplitFire Spark Plugs will work with any type of ignition system.
Q: How long will SplitFire Spark Plugs last?
A: SplitFire, Inc. guarantees that SplitFire Spark Plugs will meet or exceed your automotive or truck manufacturer's spark plug performance standards in a properly tuned automobile or truck with a non-modified engine for 36 months, regardless of mileage driven, or we will replace the spark plugs. (See our Warranty information sheet for full details of this limited warranty.)
Q: Do I need to change my timing when I put SplitFire Spark Plugs in my engine?
A: No. Use the factory specifications. If you have made modifications to your engine, you should consult the component manufacturer's specifications
March 3rd, 2005 10:07 AM #26Originally Posted by raikonen
- Sep 2004
- 58
March 4th, 2005 07:03 PM #27meron ako bnew Denso iridium for honda civics pero pwede din daw sa toyota nissan mitsubishi. check mo na lang sa classified.
- Jul 2004
- 40
October 17th, 2005 03:05 PM #28meron akong bnew denso iridium , one-thou-four-hund for the 4 piece iw16
September 17th, 2006 02:02 PM #29
chief gusto ko rin malaman kung magkanu ung iridium plug s ng denso
Toyota is my choice
- Aug 2005
- 2,063
