Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
    Jan 2003
    #21
    im using denso iridiums for 7000kms already. just had it cleaned last week, and ok pa rin up to now.
    #22
    yup. got it for 1800 (set of 4)
  3. #23
    Quote Originally Posted by ssaloon
    Pre PM mo naman sakin kung san mo nabili. TY
    Aug 2004
    #24
    Meron na ba naka-try ng SplitFire... Ito gamit ko ngayon and okay naman. Never been cleaned since kinabit 10,000 kms ago and still going strong. got it for 1,400/set..
    quote from the manufacturer:
    Q: Why should I pay more for SplitFire Spark Plugs?
    A: The key reasons: SplitFire patented split 'V' ground electrode helps deliver more complete combustion. Result: Maximum percentage of fuel is converted to combustion energy not partially burned exhaust, for performance only SplitFire can deliver.
    Q: Will SplitFire Spark Plugs work with a "high performance" ignition system?
    A: Yes. SplitFire Spark Plugs will work with any type of ignition system.
    Q: How long will SplitFire Spark Plugs last?
    A: SplitFire, Inc. guarantees that SplitFire Spark Plugs will meet or exceed your automotive or truck manufacturer's spark plug performance standards in a properly tuned automobile or truck with a non-modified engine for 36 months, regardless of mileage driven, or we will replace the spark plugs. (See our Warranty information sheet for full details of this limited warranty.)
    Q: Do I need to change my timing when I put SplitFire Spark Plugs in my engine?
    A: No. Use the factory specifications. If you have made modifications to your engine, you should consult the component manufacturer's specifications
    #25
    Quote Originally Posted by ILuvDetailing
    pre, nabili ko lang sa ads eh :D
    Dec 2003
    #26
    Quote Originally Posted by raikonen
    using splitfire on the cefiro, ok rin naman cheaper alternative to iridiums
    Sep 2004
    #27
    meron ako bnew Denso iridium for honda civics pero pwede din daw sa toyota nissan mitsubishi. check mo na lang sa classified.
    Jul 2004
    #28
    meron akong bnew denso iridium , one-thou-four-hund for the 4 piece iw16
    Jul 2006
    #29
    chief gusto ko rin malaman kung magkanu ung iridium plug s ng denso
    Aug 2005
    #30
    nice ata iridium..
    magkano kaya..
    Nov 2003
    #31
    ik16 or ik20 should be the one used on the civic.
    Aug 2006
    #32
    Quote Originally Posted by geris View Post
    guys tanong ko lang gaano kadalas dapat magpalit ng spark plug ng car kung ordinary type lang gamit ko.tnx
    You need to do a visual inspection or check your maintenance manual. If you got money to burn get an iridium plug.
    Sep 2006
    #33
    mga sir, ano po ba ang mas reliable? NGK Platinum or BOSCH Platinum? and san kaya ako makakabili ng alin dito na hindi local lng? 5ES ang pinapabili sakin.. hehehe
    thanks po!
    cheers!!!
    #34
    Quote Originally Posted by legnacilyz View Post
    thanks po!
    cheers!!!
    base on my experience, pare-pareho lang yan bro, both used them for years already,.. the advantage of Bosch Plat lang naman is you can find them almost all oto supply shops,..as for the NGK G-Power Platinum whereas there are some or most of the shops don't carry/sell them,. in short, hard to find siya, sobrang bihira.
    There are 7-8 oto supply's near my place, unfortunately none of them are selling it (yung iba, di alam kung anu yun,.then others say, wala daw ganun,.. hehe weird!). I'm looking for an NGK Plat too (G-Power), kaso I can buy them sa Banawe area pa, layo!
    Sep 2006
    #35
    ^^banawe? hmmm.. im just a tricycle ride away sa lugar na yun! maybe i should really pay a visit there! but im afraid of picking a shop that might sell me a fraud sparks! lam mo na.. banawe yan eh.. hehehe.. question ko na rin po, spark plugs po ba ang mei fault pag nagka-menor lang yung engine mo about 800rpm then may inconsistency sa menor niya? parang mei extrang nginig from time to time.. pero pag high speeds about 1000+ rpm, pinong pino nman yung rev niya.. thanks po sa reply and sa mag rereply!
    cheers!!!
    Jul 2006
    #36
    Spark plug? Ano yon? Glow plug lang ako
    Seriously though, my dad uses Denso Iridium plugs on his SiR. Kasama na rin yung Split-Fire wires.
spark plug
