Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Nov 2006
    guy's any feedback in using E10 in 1.8efi revo? i will fill up sna last night in shell macapagal kaso i noticed a piece of paper in the gas pump that shell only recommend e10 fuel for toyota car/s model starting 2006..so didn't gas up na lang..any experience w/ e10 on 1.8efi gas engine?
    salamat in advance
    Dec 2007
    Some say its good some say its corrosive... Tried it before sa 97 corona ko ok naman... but never try it in our innova... better safe than sorry
    have tried using E10 once, pero lumakas ng onti ang FC ko.
    i don't think its corrosive, for it only has 10% alcohol. and based on the mechanic that i've talked to before, ok yan sa vehicles na EFI starting 1998 upwards.
    pero again, yung cost difference nya sa price per liter, medyo negated ng fuel consumption.
    imho.
    Yup ethanol blends tend to yield much lower fuel consumption levels as compared to straight gasoline. Read in Car and Driver that it would be at around 80% only versus pure gasoline.
    Nov 2006
    ooppss.. if thats the case parang wa effect din pala,, kse base sa ibang comment E10 increased their fc, plus smoother ride daw.. madamage kaya engine ko pag nagtry ako ng e10? just to observe lang its effect on my ride..or should i mix it 1st with other fuel ( petron XCS )..
    Quote Originally Posted by bengkok View Post
    it really offers a much more smoother ride, because the fuel lines are cleaned of the fuel residues.
    hindi naman madadamage yang engine mo if you decide to try it the first time.
    and if you mix it with other fuel, it negates the effect. bibili ka ng regular fuel, tapos bibili ka ng E10. di hwag ka ng mag E10, mag regular unleaded ka na lang.
    imho, mas mararamdaman mo yung smoother ride effect, kung almost empty na yung tank mo.
    Nov 2006
    many thanks for the replies,,,1/2 pa gas level ko ngaun..try ko e10 on my next re fuel just to feel the difference
    regards...
    Oct 2004
    sir have you try E10 fuel on a honda city 1.5 model 97 ?
    Sir, what about Toyota Carb engines 1996 below?
    iam3739.com
    Sep 2005
    Eto nga pinagtataka ko dyan sa mga recommendations ng E10.. Eh noong nasa Amerika ako lahat ng fuel doon sa California E10. At wala naman nakalagay na bawal ang mga lumang sasakyan na gumamit ng E10.
    Jul 2006
    eto ngayon gamit ko.
    beside sa low fuel cost (can get P40.81) sa gas station samen
    smoother pa ang ride ko
    at saka umaabot na ng 10km/l ang takbo ko or more pa
    compare kapag nagpagas ako ng unleaded/vpower/xcs/blaze etc.
    9km/l lang takbo ko
    almost 4months na rin ako gumagamit nito at wala naman problema
    corolla 97 efi
    Quote Originally Posted by eagle View Post
    if its EFI, afaik, pwede.
    Quote Originally Posted by drey View Post
    hmmm. this one, not sure bro.
    Mar 2007
    pwede ba ito sa mga newer cars like honda city 2006? di ba makakasira? student palang kasi ako and i want na makamura sa gas hehe
    Quote Originally Posted by suysuy View Post
    yes, pwedeng pwede yan.
    If ever there are any effects (i.e. corrosion to your fuel lines), that will come out later on... even several years down the road.
    vinj, personal opinion ko lang ito ha?
    tingin ko, wala syang long-term harmful effects dahil 10% alcohol lang sya.
    actually, tingin ko yan ang kulang dito sa atin eh. medyo kulang ang information regarding usage of the ethanol-based fuel, regarding short and long term effects on the vehicle. i've tried visiting the site of Shell Philippines, pero they are mum on this. i have also done research on the manufacturers pero wala din akong makitang clear answer. i even tried sending some emails to the car manufacturers but i have not received any reply from them on this.
    ang meron akong nakita are some overseas studies with regards to the use of the 10% ethanol based fuel, which, they don't see it as having some harmful effects on the cars. but it could be different daw because some components would have to be corrosion proof, if cars that are going out would use ethanol-based fuel on more than 10%.
    Sep 2005
    ano po ba octane rating nang E10?
    afaik bro, its the same as Shell Unleaded, which i think is 92 RON.
    it's shell unleaded and e10 is 93 octane i think.
Shell E10 for 1.8 REVO'03
