Results 11 to 20 of 20
- Sep 2006
- 11
July 16th, 2007 03:25 PM #11Ganito din nangyayari sakin ngayon. Kumusta na po sasakayn nyo? Napaayos mo na?
Tsikot Member Rank 5
- Nov 2003
- 3,849
July 19th, 2007 08:49 AM #12have it mut's in casa.
walang distributor yung gsr. it uses wasted spark ignition.
- Jul 2007
- 4
July 20th, 2007 06:25 PM #14dinala ko yung car sa isang recommended(mymitsu.ph) na shop na malapit lang sa amin...kaso iba naman yung nakita at iba yun naayos...yung boot sa cv joint ang napalitan kasi butas...then inaadjust then yung clearance ng rotor at yung plate na malapit sa brakes...minsan kasi kumikiskis sila...pero chineck nila yung brake system ko...pati mga pang-ilalim...
Aside from the job done to the car wala pa din pagbabago...di pa din ako comfortable sa takbo niya...sabi naman nong mechanic kumot' automatic daw eh medyo agrabyado daw sa arangkada talaga...kaso i'm thinking na dapat hindi ganon kaagrabyado kasi 1.6 yun...nagkaron na ako ng 1.3(corolla 92) at 1.5(1995 civic lx) na car pero halos di ko maramdaman ang difference ng 1.6 ko sa arangkada nila...
So hanap-hanap at isip-isip pa din ako kung sino talaga pwede tumingin ng maayos sa car para gumanda kundisyon niya...
July 20th, 2007 11:38 PM #15agrabyado daw sa arangkada
are you experiencing unusual shift shocks/slips, late upshifts?Last edited by rion; July 21st, 2007 at 01:16 AM.
- Nov 2006
- 7
July 21st, 2007 11:35 PM #16nagpalit ka na ba ng fuel filter? try mo,ung sakin kase sakal din dati nung nagpalit ako ok na cya.
- Jul 2007
- 4
July 23rd, 2007 05:54 PM #17RION:
I am not experiencing any shift shocks/slip. But sometimes shifting to the next gear is made by the transmission when it reaches to almost 3,000 RPM. But it seldom happens, pag inaarangkada ko lang ng todo...is this considered late already? Minsan kasi 2 to 2.5 nagsishift na siya pag normal na takbo lang...
pgokou:
I haven't changed my fuel filter yet. Isa din siguro to sa dapat tingnan...
July 23rd, 2007 07:36 PM #19
- Nov 2003
- 3,849
July 23rd, 2007 10:39 PM #20shifting is determined by many factors, tps reading, speed, etc. kaya di talaga pareparehas yan.
It looks like solid state batteries are the next big thing. Will manufacturers allow retrofits to...
All New Toyota Corolla Cross
